| Re: Cannot install Visual Editor [message #143466] |
Fri, 11 January 2008 15:31  |
ex,
Have a look at some of the threads on the VE newsgroup which I've added
to the "to" list of the reply.
exquisitus wrote:
> Hello,
> I am trying to install the visual editor for eclipse.
> I followed the steps described in the project-hp but I don't get a
> Visual Editor when I right-click on a .java-file and go to "Open with".
> There is simply no Visual editor, what did I miss?
> thx,
> ex
| Re: Cannot install Visual Editor [message #143739 is a reply to message #143466] |
Wed, 23 January 2008 19:09  |
You need to check if the VE wizard is enabled:
1. Right select a Java project
2. Call the menu new ->Others->Java->Visual class
If you cannot find this wizard, you should talke a look at the log
<workspace>/.metadata/.log to see what's wrong.
Cheers
Yves YANG
http://www.soyatec.com
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fm8jqa$rlc$1@build.eclipse.org...
> ex,
> Have a look at some of the threads on the VE newsgroup which I've added to
> exquisitus wrote:
>> Hello,
>> thx,
>> ex
| Re: Cannot install Visual Editor [message #616923 is a reply to message #143466] |
Mon, 14 January 2008 11:46  |
Ed Merks wrote:
> ex,
> exquisitus wrote:
>> Hello,
See the note at the top of the VE project page: http://www.eclipse.org/vep
Hope this helps,
Eric
| Re: Cannot install Visual Editor [message #616945 is a reply to message #143466] |
Cheers
Yves YANG
> ex,
> exquisitus wrote:
>> Hello,
>> thx,
>> ex
FUDForum. Page generated in 0.04446 seconds
