Home » Eclipse Projects » SWTBot » SWTBot dev setup (how to checkout sources)
SWTBot dev setup (how to checkout sources) [message #13259] Sat, 10 January 2009 13:20 Go to next message
Ketan,
Where can I find instructions on how to set up a workspace to contribute
to SWTBot? I've looked around and found very little information.
So far I've checked out the sources, but there appears to be an
unresolved dependency on a plug-in named org.hamcrest
David
Re: SWTBot dev setup (how to checkout sources) [message #13286 is a reply to message #13259] Sat, 10 January 2009 14:24 Go to previous messageGo to next message
David Green wrote:
> Ketan,
Good point. Ketan, you may want to create a releng project similar to
what PDE and Equinox has done. For example, if you go to the PDE Wiki,
we have a link to the PSF that fetches all the sources and deps.
http://wiki.eclipse.org/PDE
http://dev.eclipse.org/viewcvs/index.cgi/pde/org.eclipse.pde .releng/pde-all.psf?view=co
~ Chris
Re: SWTBot dev setup (how to checkout sources) [message #14008 is a reply to message #13259] Sat, 10 January 2009 23:28 Go to previous message
Hi David,
SWTBot comes with a releng project and things generally work out of the
box. The build instructions are available in the readme in the releng
project.
Reg the dependencies, I've not checked in, or managed to get them into
orbit yet.
You can download the dependencies from
https://swtbot.svn.sourceforge.net/svnroot/swtbot/branches/j ava-1.5-api-spike/org.eclipse.swtbot.releng/externals/plugin s/
for now (and put them in .releng/externals/plugins)
A patched version of the eclipse test framework is available at
https://swtbot.svn.sourceforge.net/svnroot/swtbot/branches/j ava-1.5-api-spike/org.eclipse.swtbot.releng/test-sandbox/ecl ipse-test-framework-3.3.zip
(you'll need to put this into .releng/externals)
Drop in an email if there's something else you need.
-- Ketan
On 10/1/09 23:50, David Green wrote:
> Ketan,
> David
Previous Topic:another opensource GUI testing tool
Next Topic:How to show an Eclipse view that hasn't been shown previously?
Current Time: Sat Nov 08 15:47:22 EST 2025
Powered by FUDForum. Page generated in 0.03451 seconds
