Home » Language IDEs » C / C++ IDE (CDT) » Amazing Indexer syntax error
Amazing Indexer syntax error [message #143422] Mon, 18 April 2005 10:16 Go to next message
Originally posted by: Serge.Iovleff.univ-lille1.fr
with the following code
namespace N
template<class T>
class A
{ protected p;
template<class T>
class B : public A<T>
{ void foo { this->p = ...;}
} // namespace N
The indexer say that this->p is a syntax error !!!
Also the
is an error at the end of the class A !!!
Serge Iovleff
Re: Amazing Indexer syntax error [message #143431 is a reply to message #143422] Mon, 18 April 2005 10:17 Go to previous messageGo to next message
Sorry,
I'm using Eclipse 3.0
with CDT 2.1.1
Serge Iovleff
Re: Amazing Indexer syntax error [message #143442 is a reply to message #143422] Tue, 19 April 2005 02:01 Go to previous messageGo to next message
Originally posted by: daehn.hmi.de
Serge Iovleff wrote:
> namespace N
> template<class T>
> class A
> { protected p;
> template<class T>
> } // namespace N
> Also the
> Serge Iovleff
obviously there are several errors. First there is a ":" missing after
protected ("protected:"), second, your p needs a type (such as "int p")
and at last, the "()" is missing after "void foo" ("void foo()")
with this changes your code should compile.
cheers
Re: Amazing Indexer syntax error [message #143479 is a reply to message #143442] Tue, 19 April 2005 04:21 Go to previous messageGo to next message
>> namespace N
>> template<class T>
>> class A
>> { protected p;
>> template<class T>
>> } // namespace N
>> Also the
>> Serge Iovleff
> cheers
I was lazy when writing this mail...
My code is correct and compile :)
I want just to say that the cdt indexer is detecting syntax error
in a correct code.
thanks
Serge
Re: Amazing Indexer syntax error [message #143518 is a reply to message #143479] Tue, 19 April 2005 08:49 Go to previous messageGo to next message
Serge,
> > Hi,
Don't expect people to be less lazy than you are, especially if the code
you show them is incorrect and doesn't work to illustrate the issue
you're calling their attention to.
I suggest you isolate a test case, like you did, and you just copy/paste
the code instead of re-typing it.
Javier Kohen <jkohen@users.sourceforge.net>
ICQ: blashyrkh #2361802
Jabber: jkohen@jabber.org
Re: Amazing Indexer syntax error [message #143533 is a reply to message #143479] Tue, 19 April 2005 10:10 Go to previous messageGo to next message
Submit a patch and I'll look at it.
"Serge Iovleff" <Serge.Iovleff@univ-lille1.fr> wrote in message
news:d42ff4$7e3$1@news.eclipse.org...
> Chrischan a
Re: Amazing Indexer syntax error [message #143568 is a reply to message #143518] Tue, 19 April 2005 11:33 Go to previous messageGo to next message
Javier Kohen wrote:
> Serge,
>>>Hi,
thanks to Javier ;)
Re: Amazing Indexer syntax error [message #143767 is a reply to message #143533] Thu, 21 April 2005 05:23 Go to previous message
With this piece of (correct) code, the indexer report a syntax error :
void foo()
{ int p[10];
for (int k=0; k<10; k++) p[k] = k;
for (int k=0; k<10; k++) p[k] = 1; // The indexer report an error there (k++)
With this too :
template < template<class> class T>
class A
public:
void foo(T<double> &A);
template< template <class> class T>
void A<T>::foo(T<double> &A) // The indexer report an error there (T<double>)
I could not ceate a test case for all the errors in my project.
Serge
Previous Topic:JNI: Compiled succesfull, hang on execute [3/3] "StrLen.java" (1/1)
Next Topic:C/C++ Indexer Problem???
Current Time: Thu Nov 06 13:59:07 EST 2025
Powered by FUDForum. Page generated in 0.04427 seconds
