Home » Archived » Visual Editor (VE) » Does VE conflicts with RMI plugin
Does VE conflicts with RMI plugin [message #143358] Fri, 14 December 2007 16:43 Go to next message
Originally posted by: kamran.hamid.niit.edu.pk
Hello folks....
I installed VE a month before.... then i installed the RMI plugin for
eclipse form genady.net...... Now when i installed RMI plugin, my VE
plugin disappeared. And now when i again try to install it (with RMI
plugin still installed).. it is nor showing me the VE in eclipse. I have
followed all the methods.. i-e
i have added VE through "Remote Site" and it is installed seccesgully
i have added the zip files for EMF and GEF.... but it is not showing VE....
i have used the Window->reset perspective (i used this previoulsy and it
made my VE visible) but of no use
Can any one tell?
Re: Does VE conflicts with RMI plugin [message #143368 is a reply to message #143358] Sat, 15 December 2007 14:22 Go to previous message
just to get some more information please do the following:
- start your eclipse with '-console' parameter.
- type 'more' and set it to something your console window can display.
- type 'ss' to show all installed bundles.
- go forward till 'org.eclipse.ve*'
Are all VE bundles at least 'RESOLVED'? If not type 'bundle $id' where
$id is the bundle id shown in the first column in line of the ss-command.
Perhaps you get some hints why your VE don't work.
T.Gau
Kamran schrieb:
> Hello folks....
> Can any one tell?
Re: Does VE conflicts with RMI plugin [message #616911 is a reply to message #143358] Sat, 15 December 2007 14:22 Go to previous message
T.Gau
Kamran schrieb:
> Hello folks....
> Can any one tell?
Previous Topic:Does VE conflicts with RMI plugin
Next Topic:EclipseZone non update times-11/4-12/16
Current Time: Sat Nov 29 07:40:28 EST 2025
Powered by FUDForum. Page generated in 0.60802 seconds
