| eclipse console no longer showing output [message #143292] |
Thu, 16 March 2006 01:23  |
Originally posted by: dscholte.student.umass.edu
My program was outputting fine to the console on the bottom of Eclipse. I
then exited Eclipse, and reopened just a couple of minutes later. All the
code was saved and is still there, but when I hit run, nothing is
outputted. It seems the program still runs. All the files are there and
I checked run to ensure that it is looking in the correct project and the
correct class for main(). In Window->Preferences, I restored the console
outputs to default, which didn't change anything set I had not modified
them before. The console just stays a dark gray color and reads "A
console is not available" the whole time. There must be something really
simple that I did by accident to mess this up. Any response would be
appreciated, thanks.
| Re: eclipse console no longer showing output [message #143313 is a reply to message #143292] |
Thu, 16 March 2006 05:20  |
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
NotDashEscaped: You need GnuPG to verify this message
> I then exited Eclipse, and reopened just a couple of minutes later. All
> the code was saved and is still there, but when I hit run, nothing is
> and I checked run to ensure that it is looking in the correct project
> and the correct class for main(). In Window->Preferences, I restored
> the console outputs to default, which didn't change anything set I had
> not modified them before. The console just stays a dark gray color and
> reads "A console is not available" the whole time. There must be
> something really simple that I did by accident to mess this up. Any
> response would be appreciated, thanks.
Do a search for `console' in this group, and read some of the many
threads about a console not being available.
H.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFEGTwGe+7xMGD3itQRAkMkAJ9od3jO5hbwCDJb08EE5pSDTN8n7ACc C5Ka
4XPSgTk7GIjqj3EgEGdkuug=
=3rT2
-----END PGP SIGNATURE-----
FUDForum. Page generated in 0.08743 seconds
