Home » Language IDEs » Java Development Tools (JDT) » Problems while debugging only ...
Problems while debugging only ... [message #13232] Sun, 04 May 2003 22:23 Go to next message
Originally posted by: timothy.rmSolipsistic.net
This may sound strange but I'm having a problem with my java application
that only occurs when I either run, or debug, the application through
Eclipse. The particular problem is
javax.crypto.SecretKeyFactory.getInstance("PBEWithMD5AndDES ") throwing a
NoSuchAlgorithmException.
If I use NetBeans, or run it though a Jar I export, it works fine. I'm using
Sun's 1.4.1_02 sdk under linux (the 'unlimited' crypto policies don't
change things).
To illustrate things, I took a process list when it was being debugged.
Eclipse executes the app like so (I'll try to format it so it's readable):
*** Cmd Line Start ***
/opt/sun-jdk-1.4.1.02/bin/java
-Xbootclasspath:/opt/sun-jdk-1.4.1.02/jre/lib/rt.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/sunrsasign.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/jsse.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/jce.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/charsets.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/ext/dnsns.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/ext/sunjce_provider.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/ext/ldapsec.jar:
/opt/sun-jdk-1.4.1.02/jre/lib/ext/localedata.jar
-classpath /home/coder/projects/simplejab/:
/home/coder/projects/simplejab/cryptix-jce-provider.jar:
/home/coder/projects/simplejab/xercesImpl.jar:
/home/coder/projects/simplejab/xmlParserAPIs.jar
-Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp
transport=dt_socket,suspend=y,address=localhost:6440
net.solipsistic.simplejab.SimpleJabApplication
*** Cmd Line End ***
When debugging in Netbeans (which works) the command line is this:
-ea -Xdebug -Xnoagent -Xrunjdwp
transport=dt_socket,address=rhinoplasty:32867,suspend=y
-classpath /home/coder/.netbeans/3.4/system:
/opt/netbeans/system:
/opt/netbeans/modules/ext/AbsoluteLayout.jar:
/opt/netbeans/beans/TimerBean.jar:
/home/coder/projects/simplejabcopy:
/home/coder/projects/simplejabcopy/cryptix-jce-provider.jar:
/home/coder/projects/simplejabcopy/xercesImpl.jar:
/home/coder/projects/simplejabcopy/xmlParserAPIs.jar
At first glance it seems like maybe the -Xbootclass option eclipse provides
is doing something to this process ... but I really am at a loss here. I've
looked over all of the Debug options/preferences and cannot find anything
that helps.
Does anyone else have any ideas?
Tim
Re: Problems while debugging only ... [message #15968 is a reply to message #13232] Tue, 06 May 2003 19:22 Go to previous message
Well, get this. Couldn't reproduce this on my Win2k partition, or my other
linux box. So I uninstalled all my jdk's and eclipse, wiped out my
workspace directory, and started from scratch. This time it works! I have
no clue what I managed to do, but it's working now ...
Timothy Bogdala wrote:
> Hello,
> application
> using Sun's 1.4.1_02 sdk under linux (the 'unlimited' crypto policies
> don't change things).
> provides is doing something to this process ... but I really am at a loss
> here. I've looked over all of the Debug options/preferences and cannot
> find anything that helps.
> Tim
Previous Topic:can't format selections
Next Topic:Eclipse and Emacs - newbie
Current Time: Wed Oct 29 06:26:09 EDT 2025
Powered by FUDForum. Page generated in 0.03213 seconds
