Home » Eclipse Projects » Eclipse Platform » BUG? PDE creating build.xml ignores Java settings
BUG? PDE creating build.xml ignores Java settings [message #143245] Mon, 13 October 2003 14:23 Go to next message
The build.xml file needed for exporting (read creating) a plugin seems to be
created without looking at the Java Version preferences.
You can reproduce this bug when creating a Plugin (say the Hello World
Plugin example), insert an assertion anywhere in the sourcecode. Doing this
you must switch the compiler compatibility to 1.4. If you do so either in
the project preferences or in the eclipse global preferences and then create
the build.xml file (right mouse click on plugin.xml->create build.xml) the
resulting code contains the line on top:
<property name="javacSource" value="1.3"/>
<property name="javacTarget" value="1.1"/>
which should be 1.4 both times.
Is there a workaround? Am I missing something. So far I generated those
scripts and the set
custom=true
in the build.properties then edited the build.xml to reflect the correct
setting.
Is there a better way? This bug was present in verion 3.0 M3 and now in M4.
- Clemens
Re: BUG? PDE creating build.xml ignores Java settings [message #143265 is a reply to message #143245] Mon, 13 October 2003 15:08 Go to previous messageGo to next message
OK, did a little more research... I guess the culprit is in
org.eclipse.pde.internal.build.builder.ModelBuildScriptGener ator
449: script.printProperty(PROPERTY_JAVAC_SOURCE, "1.4"); //$NON-NLS-1$
450: script.printProperty(PROPERTY_JAVAC_TARGET, "1.4"); //$NON-NLS-1$
Is this worth filing a bug report?
- Clemens
"Clemens Drews" <cdrews@us.ibm.com> wrote in message
news:bmesuv$jh9$1@eclipse.org...
be
this
create
> scripts and the set
> custom=true
> setting.
M4.
> - Clemens
Re: BUG? PDE creating build.xml ignores Java settings [message #143285 is a reply to message #143265] Mon, 13 October 2003 15:10 Go to previous messageGo to next message
Sorry for any confusion, the String "1.4" below is what I hardcoded to make
my projects run, it used to be "1.3" for source compatibility and "1.1" for
Target VM.\
- Clemens
news:bmet7r$jp8$1@eclipse.org...
> - Clemens
> > Hi,
to
> be
> this
in
> create
the
> > scripts and the set
> > custom=true
> > setting.
> M4.
> > - Clemens
Re: BUG? PDE creating build.xml ignores Java settings [message #149193 is a reply to message #143245] Fri, 24 October 2003 15:10 Go to previous message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
This one confused me too. PDE has its own Java version preferences in Window
> Preferences > Plug-in Development > Build Options.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=44821, especially at the
end.
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
be
this
create
> scripts and the set
Previous Topic:Eclipse "HELP" Link
Next Topic:new Eclipse article: Mutatis mutandis - Using Preference Pages as Property Pages
Current Time: Thu Nov 20 23:35:43 EST 2025
Powered by FUDForum. Page generated in 0.07441 seconds
