Home » Modeling » GMF (Graphical Modeling Framework) » problem with displaying inheritance node in a Compartment
problem with displaying inheritance node in a Compartment [message #143228] Wed, 18 July 2007 07:04 Go to next message
I have a problem with displaying a "inherited" class in a compartment. I
place it properly but it just won't display.
Let's say I have those classes in my model :
Nature:
- trees: Tree (container reference)
Tree:
-name
-apples: Apple (container reference)
-specialApples: SplecialApple (container reference)
Apple:
-color
SpecialApple
-specialAttribute
The class SpecialApple "extends" the class Apple.
In my gmfmap I have a TopNodeReference to with a NodeMapping to a Tree.
This NodeMapping has ChildReferences to "Apple" and "SpecialApple" . It also
has a Compartment Mapping with Children set to Apple and SpecialApple.
So my problem is when I run the diagram, I can place and Apple to the
Compartment. I can also place the SpecialApple but when I release the mouse
button, it just doesn't show in the diagram. If I open the xmi file of the
model instance, I can see the SpecialApple.
When I remove the inheritance between the Apple and SpecialApple, it works
ok !!
Any ideas ?
Thanks a lot,
Tex;
Re: problem with displaying inheritance node in a Compartment [message #143281 is a reply to message #143228] Wed, 18 July 2007 10:57 Go to previous messageGo to next message
Hi again,
I've also noticed that if I put two Compartments - one for Apples, one for
SpecialApple - it works also fine.
Any ideas how to solve this problem ?
Thanks.
"Tex Twil" <chaljan@hotmail.com> a écrit dans le message de
news:f7ks4k$pk2$1@build.eclipse.org...
> Hello,
> Nature:
> Tree:
> -name
> Apple:
> -color
> SpecialApple
> -specialAttribute
> also has a Compartment Mapping with Children set to Apple and
> SpecialApple.
> mouse button, it just doesn't show in the diagram. If I open the xmi file
> of the model instance, I can see the SpecialApple.
> ok !!
> Any ideas ?
> Thanks a lot,
> Tex;
Re: problem with displaying inheritance node in a Compartment [message #143301 is a reply to message #143281] Wed, 18 July 2007 11:17 Go to previous messageGo to next message
hi Tex,
its a bug in the ???VisualIDRegistry within the method getNodeVisualID().
the problem is that types are listed from general to specialized.
so the first matching (super)type in the hierarchy is returned instead
of the most specialized type.
if allready commited a bug report
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195272
a simple workaround is just to change the order of 'if' operations with
the types ordered from specialized to general.
andreas
Tex Twil schrieb:
> Hi again,
> for SpecialApple - it works also fine.
> Thanks.
>> Hello,
>> I place it properly but it just won't display.
>> Nature:
>> Tree:
>> -name
>> Apple:
>> -color
>> SpecialApple
>> -specialAttribute
>> Tree. This NodeMapping has ChildReferences to "Apple" and
>> "SpecialApple" . It also has a Compartment Mapping with Children set
>> file of the model instance, I can see the SpecialApple.
>> works ok !!
>> Any ideas ?
>> Thanks a lot,
>> Tex;
Re: problem with displaying inheritance node in a Compartment [message #143410 is a reply to message #143301] Thu, 19 July 2007 05:05 Go to previous messageGo to next message
Hi Andreas,
Thank you for your hint, it helped.
Tex
"A.Schuster" <a.schuster@exxcellent.de> a écrit dans le message de
news:f7lavi$ve3$1@build.eclipse.org...
> hi Tex,
> so the first matching (super)type in the hierarchy is returned instead of
> andreas
> Tex Twil schrieb:
>> Hi again,
>> Thanks.
>>> Hello,
>>> Nature:
>>> Tree:
>>> -name
>>> Apple:
>>> -color
>>> SpecialApple
>>> -specialAttribute
>>> SpecialApple.
>>> works ok !!
>>> Any ideas ?
>>> Thanks a lot,
>>> Tex;
Re: problem with displaying inheritance node in a Compartment [message #144004 is a reply to message #143301] Wed, 25 July 2007 07:14 Go to previous messageGo to next message
Hello A.Schuster,
The problem is not in the generated code, but in the mapping model itself.
I've attached detailed description to your request so you should be able
to correct an error.
Alex Shatalin
Re: problem with displaying inheritance node in a Compartment [message #144013 is a reply to message #143410] Wed, 25 July 2007 07:14 Go to previous message
Hello Tex,
Try following suggestions from: https://bugs.eclipse.org/bugs/show_bug.cgi?id=195272#c6
Alex Shatalin
Previous Topic:How to get the instance of XXXDiagramEditor at runtime?
Next Topic:Re: EMF/GMF visual editor generation - Changing the containment of elements
Current Time: Sat Nov 08 06:00:39 EST 2025
Powered by FUDForum. Page generated in 0.06298 seconds
