Home » Language IDEs » C / C++ IDE (CDT) » processType for C/C++ Local Application launch config
processType for C/C++ Local Application launch config [message #143211] Wed, 13 April 2005 10:44 Go to next message
I'm attempting to make use of the org.eclipse.debug.ui.consoleLineTrackers
extension point to parse the output from running a 'C/C++ Local
Application'. I can get this to work for a Java app by using:
<extension
point="org.eclipse.debug.ui.consoleLineTrackers">
<consoleLineTracker
id="com.ipl.products.cantpp.eclipse.parsers.outputparser"
class="com.ipl.products.cantpp.eclipse.parsers.OutputParser "
processType="java">
</consoleLineTracker>
</extension>
Unfortunately CDT doesn't appear to set ATTR_PROCESS_TYPE when it creates
a process so I'm not able to specify an appropriate processType.
Can someone confirm if I'm correct, or tell me what the correct
processType would be?
Richard
Re: processType for C/C++ Local Application launch config [message #143221 is a reply to message #143211] Wed, 13 April 2005 13:31 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
You're right the CDT doesn't set ATTR_PROCESS_TYPE. Please, submit an
enhancement request to the cdt-launch component.
"Richard Miskin" <richard.miskin@ipl.com> wrote in message
news:f5341d7981001eadd83b1f360e433c40$1@www.eclipse.org...
> <extension
> <consoleLineTracker
> processType="java">
> </extension>
> Cheers,
> Richard
Re: processType for C/C++ Local Application launch config [message #143264 is a reply to message #143221] Thu, 14 April 2005 05:10 Go to previous message
Thanks for your help.
I've now raised an enhancement request as you suggested.
Richard
>> <extension
>> <consoleLineTracker
>> processType="java">
>> </extension>
>> Cheers,
>> Richard
Previous Topic:Referenced project linking error
Next Topic:Why New Project wizard checks if dirs overlap?!
Current Time: Sat Nov 08 11:07:02 EST 2025
Powered by FUDForum. Page generated in 0.03515 seconds
