Existing VE source and new Workspace NO VE palette nor Designer pane displaying [message #143210] |
Thu, 29 November 2007 10:39  |
Originally posted by: Andy.Faust.ColumbiaUltimate.com
A new developer in our company is configuring his computer for development,
has installed Eclipse v3.2, along with the VE 1.2 and associated components
(ie EMF, GEF). He can design/write new classes without trouble. However,
pre-existing visual classes source code is loaded onto his computer, and
'linked' into his workspace, he can run the classes without trouble;
however, the VE does NOT display the palette nor the designer window...only
the source code edit window.
Assuming all software/plugin versions are the same, ie everything is v3.2
using VE v1.2; what is the correct process for taking previously developed
visual classes on one computer, and moving those source files to another
developer's computer, and have Eclipse & VE work with the moved code
correctly?
The problem we are having now is if Developer A receives code from Developer
B; developer A's Eclipse/VE editor doesn't display the UI palette nor the
designer window, only the source code edit window.
FUDForum. Page generated in 0.04367 seconds
