Problems with Eclipse TPTP profiling [message #143209] |
Thu, 16 July 2009 05:25  |
Hi All,
I have installed a Java JDK 6 (version 1.6.0_11) then downloaded the
release build - TPTP 4.6.0 (TPTP all-in-one package, Windows).
Steps by steps explanation:
1. Unzip the tptp.runtime.allInOne.win32.win32.x86-TPTP-4.6.0.zip
and launched the eclipse.exe.
2. Created the java project and then java class( Carmodel.java ,
please check the attachment)
3. Right click on the Carmodel.java file and then click on the
profile.
When I launch the Java application locally for profiling, I got
the following error message:
In Console View:
JVMJ9TI001E Agent library JPIBootLoader could not be opened (The specified
module could not be found. )
JVMJ9VM015W Initialization error for library j9jvmti23(-3): JVMJ9VM009E
J9VMDllMain failed
Could not create the Java virtual machine.
Popup window appear with the message:
'The JVMTI agent org.eclipse.tptp.jvmti is not available. Make sure that
the agent's libraries are available and that it is configured properly.
Can u please tell me why these errors are coming?
As I am profiling locally so I dont think I need the AC and environment
variable setting? If I do need then can u please explain in detail the
setting of environment variable (I am getting confuse with this).
Thanks in advance.
Gopal
FUDForum. Page generated in 0.34455 seconds
