Home » Archived » Test and Performance Tools Platform (TPTP) » Problems with Eclipse TPTP profiling
Problems with Eclipse TPTP profiling [message #143209] Thu, 16 July 2009 05:25 Go to next message
Hi All,
I have installed a Java JDK 6 (version 1.6.0_11) then downloaded the
release build - TPTP 4.6.0 (TPTP all-in-one package, Windows).
Steps by steps explanation:
1. Unzip the “tptp.runtime.allInOne.win32.win32.x86-TPTP-4.6.0.zip”
and launched the eclipse.exe.
2. Created the java project and then java class( Carmodel.java ,
please check the attachment)
3. Right click on the Carmodel.java file and then click on the
profile.
When I launch the Java application locally for profiling, I got
the following error message:
In Console View:
JVMJ9TI001E Agent library JPIBootLoader could not be opened (The specified
module could not be found. )
JVMJ9VM015W Initialization error for library j9jvmti23(-3): JVMJ9VM009E
J9VMDllMain failed
Could not create the Java virtual machine.
Popup window appear with the message:
'The JVMTI agent org.eclipse.tptp.jvmti is not available. Make sure that
the agent's libraries are available and that it is configured properly.
Can u please tell me why these errors are coming?
As I am profiling locally so I don’t think I need the AC and environment
variable setting? If I do need then can u please explain in detail the
setting of environment variable (I am getting confuse with this).
Thanks in advance.
Gopal
Re: Problems with Eclipse TPTP profiling [message #143249 is a reply to message #143209] Thu, 16 July 2009 16:28 Go to previous message
Please see my comment in another thread of the same topic.
"Gopal " <gopal.pagrut@gemalto.com> wrote in message
news:2346d317ce254e202eb95916386b5349$1@www.eclipse.org...
> Hi All,
> 1. Unzip the
Previous Topic:Using TPTP to profile an Eclipse Plugin
Next Topic:Running TPTP
Current Time: Fri Jul 18 00:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.05567 seconds
