Home » Language IDEs » Java Development Tools (JDT) » Creating a VM instance programatically
Creating a VM instance programatically [message #143197] Wed, 18 February 2004 18:32 Go to next message
Originally posted by: handcock.redhat.com
Does anyone know how to create an installed VM definition programatically?
ie. I 'm trying to add a JVM at /foo/bar/java_home to the Eclipse
preferences using Eclipse API calls.
Jeremy
Re: Creating a VM instance programatically [message #143325 is a reply to message #143197] Thu, 19 February 2004 09:12 Go to previous messageGo to next message
Create an instance of a VMStandin, set its properties/attributes, and then
call "convertToRealVM". This will add it to the JRE definitions.
Darin
"Jeremy Handcock" <handcock@redhat.com> wrote in message
news:c10smj$5km$1@eclipse.org...
> Jeremy
Re: Creating a VM instance programatically [message #144065 is a reply to message #143325] Fri, 20 February 2004 12:08 Go to previous messageGo to next message
Thanks, Darin.
I'm somewhat of an eclipse newbie. This snippet doesn't seem to be
working for me:
StandardVMType stdvmtype = new StandardVMType();
VMStandin standin = new VMStandin(stdvmtype, "someUniqueID");
standin.setInstallLocation(new File("/opt/IBMJava2-141"));
standin.setName("IBMJava2-141");
IVMInstall realVM = standin.convertToRealVM();
try {
JavaRuntime.setDefaultVMInstall(realVM, null, true);
} catch(Exception e) {
e.printStackTrace();
Whenever I try to setDefaultVMInstall, I get a NPE at
org.eclipse.jdt.internal.launching.CompositeId.toString(Comp ositeId.java:42).
Are there additional things that I need to define in the VMStandin before
calling convertToRealVM()?
Thanks.
Jeremy
> > Thanks,
> > Jeremy
Re: Creating a VM instance programatically [message #144643 is a reply to message #144065] Mon, 23 February 2004 09:29 Go to previous messageGo to next message
You should not create an instance of "StandardVMType", you should retrieve
it from the launching plug-in
JavaRuntime.getVMInstallType(String id).
The id for a standard VM type is
"org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType".
Darin
news:c15eu6$c93$1@eclipse.org...
then
> Thanks, Darin.
> working for me:
> try {
> Thanks.
> Jeremy
programatically?
> > > Thanks,
> > > Jeremy
Re: Creating a VM instance programatically [message #144688 is a reply to message #144643] Mon, 23 February 2004 10:42 Go to previous message
Ah, I see. Excellent... got this to work now. Thanks for your help, Darin.
Jeremy
> Darin
> then
>>Thanks, Darin.
>>working for me:
>>try {
>>Thanks.
>>Jeremy
> programatically?
>>>>Thanks,
>>>>Jeremy
Previous Topic:Console Terminate and addShutdownHook(Thread)
Next Topic:Setting tab behavior for all editors
Current Time: Wed Nov 05 04:00:06 EST 2025
Powered by FUDForum. Page generated in 0.27809 seconds
