Home » Archived » Test and Performance Tools Platform (TPTP) » Using TPTP to profile an Eclipse Plugin
Using TPTP to profile an Eclipse Plugin [message #143172] Tue, 14 July 2009 11:28 Go to next message
I’m currently trying to profile an Eclipse Plugin using the TPTP tools.
However, I have run into issues when trying to profile an plugin. I can
profile a Java application fine, however when I try to profile an plugin,
the runtime workbench fails to load and the profiling terminates after a
few seconds.
I’m at a lost to what I’m doing wrong; I’m using Eclipse 3.4.0 and have
the following TPTP features installed. Is there something I’m missing?
org.eclipse.tptp.platform.analysis
(4.4.101.v200901090956-7F7_EC6_kE77g7A7g7A77) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.4.201.v200901090956-7877_98s733K353K3533) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.300.v200901090956-784CE8s733J464H3533) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core
(4.5.2.v200901090956-8Z8DF8kELRXmqCoI2oujyq) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.301.v200901090956-7B6EC49oA55U697O5855) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.doc.user
(4.3.301.v200901090956-7B77EC58_JLz0Y3HuPJBbBLAT9B6) "TPTP Platform
Project Documentation"
org.eclipse.tptp.platform.instrumentation.ui
(4.2.200.v200901090956-78778a8s733K353K3533) "TPTP Instrumentation UI Core"
org.eclipse.tptp.platform.integration.pde
(4.4.100.v200901090956-438Y7w311_121_1211) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti
(4.3.201.v200901090956-7877CF8s733K364J3533) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core
(4.3.200.v200812160100-42_77w311923271211) "Log Analysis Core backward
compatibility"
org.eclipse.tptp.platform.lta (4.3.300.v200901090956-783Dp8s733J464H3533)
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit
(4.3.301.v200901090956-7F5ELS_kE77g7A9g7A77) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.300.v200901090956-41Ag7w311_121_1211) "Probekit User Documentation"
org.eclipse.tptp.platform.report
(4.2.300.v200901090956-7B5EAU9oA55V585V5855) "TPTP Charting Service"
org.eclipse.tptp.platform.samples
(4.3.300.v200901090956-7B4EDc9oA55V586R5855) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui
(4.1.500.v200901090956-783CE8s733J365H3533) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace
(4.3.301.v200901090956-7J7EEFFAgI99r9EAh9D99) "TPTP Platform Trace"
org.eclipse.tptp.trace (4.2.201.v200901090956-781EDf8s733K353K3KCE) "TPTP
Trace"
org.eclipse.tptp.trace.arm (4.2.200.v200901090956-782CE8s733K353K3KCE)
"TPTP ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.200.v200901090956-785Ag8s733K353K3KCE)
"Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.201.v200901090956-43_87w311_12211211)
"TPTP Trace JVMTI Client"
Re: Using TPTP to profile an Eclipse Plugin [message #143183 is a reply to message #143172] Tue, 14 July 2009 11:56 Go to previous messageGo to next message
Hi Rich,
Did you get any error and how did the profiling session fail?
Eugene
"Rich " <kingamajick@gmail.com> wrote in message
news:5dd3a326ae9daec5d1195011098d1d2a$1@www.eclipse.org...
> I
Re: Using TPTP to profile an Eclipse Plugin [message #143191 is a reply to message #143183] Wed, 15 July 2009 05:09 Go to previous messageGo to next message
Hi Eugene,
The only messages I'm seeing in the log are as follows:
!ENTRY org.eclipse.tptp.platform.common.ui.trace 0 0 2009-07-14
11:39:01.435
!MESSAGE Processed: 2281 bytes, bytes/second: 325, events processed: 0,
events/second: 0, elapsed time: 7 seconds
No error message is displayed before the profiling session terminates, it
just appears to end silently.
Rich
Re: Using TPTP to profile an Eclipse Plugin [message #143200 is a reply to message #143191] Wed, 15 July 2009 13:52 Go to previous message
Hi Rich,
I beleive you have hit bug 280841. The bug is fixed in the final build of
TPTP 4.6.
Eugene
news:b380bcc7849ffc41237b5630c32e6611$1@www.eclipse.org...
> Hi Eugene,
> 11:39:01.435
> Thanks
> Rich
Previous Topic:TPTP going to die?
Next Topic:Problems with Eclipse TPTP profiling
Current Time: Fri Jul 18 22:19:09 EDT 2025
Powered by FUDForum. Page generated in 0.04799 seconds
