Home » Language IDEs » C / C++ IDE (CDT) » Eclipse 3.1M6/CDT I200504120301 indexer problem
Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143170] Wed, 13 April 2005 02:46 Go to next message
Originally posted by: d98_ama.hotmail.com
It seems like the indexer is doing a full "rebuild" every time I start
Eclipse. It is quite annoying since it takes at least 30 minutes.
Has any one else seen this? Any hints on where I can look to find out why
this occurs (I've just started to use CDT)??
/Anders
Re: Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143201 is a reply to message #143170] Wed, 13 April 2005 10:19 Go to previous messageGo to next message
Hi Anders -
There is a bug for this (Bug# 91145 ) - but we're having a tough time
reproducing it all times. If you could add the exact steps you took to
create
your project (ie. Went to Project Wizrard->Selected Standard C++
Project->Selected DOM Indexer->Checked Index enabled etc.) that might
help us track this down.
Bogdan
"Anders Magnusson" <d98_ama@hotmail.com> wrote in message
news:8895a723cb39b0b232fcb079d93156e0$1@www.eclipse.org...
> /Anders
Re: Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143232 is a reply to message #143201] Wed, 13 April 2005 14:15 Go to previous messageGo to next message
Originally posted by: mark_melvin.amis.com
Could this possibly be related to the platform bug I came across here?:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=89965
It sounds different from Bug 91145, but may be the cause of Anders's
issue (however, I know nothing about the internals of the CDT's indexer).
It should be fixed in the latest integration builds - I think. You may
want to check it out and see if this is what causing the indexer to
re-index everything.
Mark.
Bogdan Gheorghe wrote:
> Hi Anders -
> create
> Bogdan
>>Hi,
>>/Anders
Re: Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143254 is a reply to message #143201] Thu, 14 April 2005 02:14 Go to previous messageGo to next message
I don't remeber exactly how I did it. I followed a tutorial on the CDT web
page, and I do remember that it told me to not check the indexer while
creating the project (in the tutorial the indexer was enabled later), but
I did any way.
One thing I noticed now is that I'm using the "Original C/C++ Indexer"
(the project was created with CDT 2.1). Should I switch to the DOM
indexer??
/Anders
Re: Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143527 is a reply to message #143254] Tue, 19 April 2005 10:09 Go to previous message
Do not switch to the DOM Indexer until at least M7.
JC
news:53ec5fc9c7c13b83c7af553f6163c4a9$1@www.eclipse.org...
> I did any way.
> indexer??
> /Anders
Previous Topic:CDT Build Source Code?
Next Topic:CDT3 C++ Indexer
Current Time: Wed Nov 05 06:25:55 EST 2025
Powered by FUDForum. Page generated in 0.04143 seconds
