| problem in linux eclipse [message #143134] |
Wed, 15 March 2006 07:07 |
Originally posted by: fermi.cs.usm.my
I hve a network monitoring application (RCP) consist of several plug-ins.
the application runs fine on windows (xp sp2) but have problems in Linux
(slackware 10.2).
the problem is I can run the application in Linux as normal user but the
it failed to run when I login as root. the case is if I run the
application as normal user, the application can't see the list of network
adapter as this would require root privilege. but then if I run the
application as root it crashed before running (I can see the GUI in a
flash, then it ask me to see the error log).
Help anyone?
Fermi
ps. here are the error (huge log):
!SESSION 2006-03-15 20:00:47.587
eclipse.buildId=unknown
java.version=1.5.0_04
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -application com.inetmon.jn.app -pdelaunch
Command-line arguments: -application com.inetmon.jn.app -data
/root/eclipse/runtime-workspace -dev
file:/root/eclipse/workspace/.metadata/.plugins/org.eclipse. pde.core/jNetmon/dev.properties
-pdelaunch -debug -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2006-03-15 20:00:49.772
!MESSAGE An error occurred while automatically activating bundle
com.inetmon.jn.core (5).
!STACK 0
org.osgi.framework.BundleException: Exception in
com.inetmon.jn.core.CorePlugin.start() of bundle com.inetmon.jn.core.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1013)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:316)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1248)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:240)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:236)
org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor.java:99)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:267)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 2)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:269)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:528)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:485)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:230)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:813)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2201)
org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:2356)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2338)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:681)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:669)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1282)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1223)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:706)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at com.inetmon.jn.internal.JNetmonApp.run(JNetmonApp.java:56)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of
range: -1
at java.lang.String.substring(Unknown Source)
at com.inetmon.jn.core.engine.NetworkDevices.init(NetworkDevice s.java:65)
at com.inetmon.jn.core.CorePlugin.start(CorePlugin.java:99)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
... 80 more
Root exception:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
!ENTRY org.eclipse.osgi 2006-03-15 20:00:49.788
com.inetmon.jn.examples.packetmodellistener (9).
!STACK 0
org.osgi.framework.BundleException: The activator
com.inetmon.jn.examples.packetmodellistener.PacketModelListe nerPlugin for
bundle com.inetmon.jn.examples.packetmodellistener is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:149)
Caused by: java.lang.NoClassDefFoundError:
com/inetmon/jn/core/engine/IRawPacketListener
... 63 more
Root exception:
!ENTRY org.eclipse.core.runtime 4 1 2006-03-15 20:00:49.794
!MESSAGE Unable to create view ID
com.inetmon.jn.examples.packetmodellistener.view: Plug-in
com.inetmon.jn.examples.packetmodellistener was unable to load class
com.inetmon.jn.examples.packetmodellistener.views.PacketList enerView.
!STACK 0
java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:405)
!ENTRY org.eclipse.osgi 2006-03-15 20:00:50.162
!STACK 0
com.inetmon.jn.internal.JNetmonWindowAdvisor.postWindowOpen( JNetmonWindowAdvisor.java:89)
org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(Wor kbenchWindow.java:1070)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:701)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:677)
range: -1
... 35 more
Root exception:
!ENTRY org.eclipse.ui.workbench 4 0 2006-03-15 20:00:50.172
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDispo sed(WorkbenchPartReference.java:151)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:101)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1045)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1026)
at org.eclipse.swt.widgets.Widget.releaseWidget(Widget.java:932 )
at org.eclipse.swt.widgets.Control.releaseWidget(Control.java:2 395)
at org.eclipse.swt.widgets.Scrollable.releaseWidget(Scrollable. java:313)
at org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:948)
at org.eclipse.swt.widgets.Widget.releaseResources(Widget.java: 927)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:942)
at org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:947)
at org.eclipse.swt.widgets.Canvas.releaseWidget(Canvas.java:132 )
at org.eclipse.swt.widgets.Decorations.releaseWidget(Decoration s.java:472)
at org.eclipse.swt.widgets.Shell.releaseWidget(Shell.java:1590)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:403)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:1532)
at org.eclipse.swt.widgets.Display.release(Display.java:2620)
at org.eclipse.swt.graphics.Device.dispose(Device.java:212)
at com.inetmon.jn.internal.JNetmonApp.run(JNetmonApp.java:64)
!ENTRY org.eclipse.osgi 2006-03-15 20:00:50.182
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: com/inetmon/jn/core/CorePlugin
FUDForum. Page generated in 0.10128 seconds
