Home » Newcomers » Newcomers » J2SE 5.0 - generic types
J2SE 5.0 - generic types [message #13179] Sun, 23 January 2005 12:01 Go to next message
Originally posted by: grape94.hotmail.com
I want to use generic types, for example:
ArrayList<Integer> list = new ArrayList<Integer>();
I am using eclipse 3.0.1, but it gives a syntax error and I am therefore
unable to compile.
Is it impossible to use generic types (and the other features unique to
J2SE 5.0) in eclipse or is there something I am missing? :)
Re: J2SE 5.0 - generic types [message #13207 is a reply to message #13179] Sun, 23 January 2005 12:23 Go to previous messageGo to next message
Eclipse 3.0.1 does not support 5.0.
Try Eclipse 3.1 M4 for the latest 5.0 support.
Darins
"Juliet" <grape94@hotmail.com> wrote in message
news:ct0l99$bt1$1@www.eclipse.org...
> Hi
> unable to compile.
Re: J2SE 5.0 - generic types [message #21714 is a reply to message #13207] Mon, 31 January 2005 15:44 Go to previous messageGo to next message
Originally posted by: rossetti.uark.edu
Darin,
I'm having the same problem. I'm using Eclipse Version: 3.0.1
Build id: 200409161125 and I get syntax errors with a simple program like:
public class TestGenerics {
List<String> list = new LinkedList<String>();
list.add("A");
list.add("B");
list.add("C");
System.out.println(list);
Exception in thread "main" java.lang.Error: Unresolved compilation
problems:
Syntax error on token "<", invalid AssignmentOperator
Syntax error on token "=", != expected
Syntax error on token "<", ( expected
Syntax error on token "(", invalid Expression
jsl.modeling.elements.processview.description.TestGenerics.m ain(TestGenerics.java:20)
I don't know how to get Eclipse to recognize the 1.5 features. I have
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_01-b08
Did moving to Eclipse 3.1 M4 fix your problem?
Manuel
> Darins
>> Hi
>> unable to compile.
Re: J2SE 5.0 - generic types [message #21803 is a reply to message #21714] Mon, 31 January 2005 16:04 Go to previous message
yes you will have the same error unless you move to Eclipse 3.1 (m4)
Eclipse has its own compiler that is just completing 5.0 support now.
HTH
Darins
"Manuel" <rossetti@uark.edu> wrote in message
news:ctm5bj$dtk$1@www.eclipse.org...
> Darin,
> public static void main(String[] args) {
> list.add("A");
> list.add("B");
> list.add("C");
> problems: Syntax error on token "<", invalid AssignmentOperator
> at
> Manuel
>> Darins
>>> Hi
>>> unable to compile.
Previous Topic:Eclipse does not start - ExceptionInInitializerError
Next Topic:How do I install plugins ?
Current Time: Tue Jul 22 12:09:15 EDT 2025
Powered by FUDForum. Page generated in 0.31677 seconds
