Home » Language IDEs » ServerTools (WTP) » plz! help me, this problem is hunting me down !
plz! help me, this problem is hunting me down ! [message #142712] Fri, 07 October 2005 05:19 Go to next message
i have installed eclipse 3.1 and wtp plugin.Now, While creating any
dynamic web project,EJB Project,J2EE Project etc... eclipse performs some
xml file check in internet and one window(web page from java.sun.com) is
displayed prompting that i have to agree with the terms. i clicked the "I
Agree" button and the dynamic project folder is marked with wrong
symbol("X").by examination i understood that there is some problem with
the web.xml file in WebContents folder(same problem in application.xml
incase of J2EE Project) I am fed up with this hell bug! I don't know how
to proceed! plz give an appropriate answer.
thanks in advance
milin
Re: plz! help me, this problem is hunting me down ! [message #142732 is a reply to message #142712] Fri, 07 October 2005 06:52 Go to previous messageGo to next message
Originally posted by: thisisnot.mymail.com
Make sure that the schema version for the web.xml respects the elements
that you want to use (validation might fail as often people use the old
web.xml format and the schema specified is the new format).
> some xml file check in internet and one window(web page from
> java.sun.com) is displayed prompting that i have to agree with the
> terms. i clicked the "I Agree" button and the dynamic project folder is
> marked with wrong symbol("X").by examination i understood that there is
> some problem with the web.xml file in WebContents folder(same problem in
> application.xml incase of J2EE Project) I am fed up with this hell bug!
> I don't know how to proceed! plz give an appropriate answer.
> thanks in advance
> milin
Re: plz! help me, this problem is hunting me down ! [message #142743 is a reply to message #142712] Fri, 07 October 2005 07:06 Go to previous messageGo to next message
Hmm..
which Eclips 3.1 version? Eclipse 3.1.1?
Which WTP version? is it WTP 0.71?
Lets check the obvious..
Window->Prefernces->Internet-Cache
You should see the dtds and xsd that Eclispe checked aginst listed there..is SUn's dtds and xsds listed?
Re: plz! help me, this problem is hunting me down ! [message #142752 is a reply to message #142712] Fri, 07 October 2005 07:56 Go to previous messageGo to next message
Originally posted by: gregpentz.mtn.co.za
Hi Me Too
I'm running 3.1.1 and 0.7.1.... was excited to see an update, but it does
exactly them same.
it also seems to be ignoring the cache.
I create a helloworld servlet... it takes minutes and then finally deploys
and runs in tomcat... I think great it's all cached now... and create a
second hello world servlet to test the theory and it does the same stupid
thing!!!
I think that a way around might be to add a whole bunch of required xsd
files to the XML catalog... but I honestly don't feel like going to great
pains to figure it out....
I've read that everyone is moaning about the same thing.... I think that
this is such a common issue that it should be added to the FAQ. Also why
is the update site not *up to date?*... had to install everything manually
Ciao
Re: plz! help me, this problem is hunting me down ! [message #142838 is a reply to message #142712] Fri, 07 October 2005 16:48 Go to previous messageGo to next message
Hi, I was having a similar problem, fixed it by setting the proxy in
Preferences -> Internet -> Proxy Settings
HTH
-- Hernan
To Hernan [message #142867 is a reply to message #142838] Sat, 08 October 2005 01:15 Go to previous messageGo to next message
dear hernan,
can u exactly tell me how did u fix this issue?
milin,
thanks for ur response
To Srgjan Srepfler from milin [message #142881 is a reply to message #142732] Sat, 08 October 2005 01:26 Go to previous messageGo to next message
>> thanks in advance
>> milin
>>dear srepfler,
The web.xml file,which causing problem is a system generated
file(genereated at the time of dynamic web pro creation by eclipse) so i
have no idea how to deal with it.I wonder why each and every time,the xml
file validation
goes to the internet and even if i choose "I Agree", The same problem
persists. Plz help me!
very much thankful for ur response
milin
To fred.grott [message #142894 is a reply to message #142743] Sat, 08 October 2005 01:32 Go to previous message
dear fred,
i am using eclipse 3.1 and wtp 7.0. The sun's webpage doesnot
containn any listings etc...it is a usual web page. is there any problem
with cache and if it has, how to fix it?
thanks,
milin
Previous Topic:Questions on creating a Apache Derby Server definition in WTP
Next Topic:This has to be frustrating....
Current Time: Wed Nov 19 03:39:31 EST 2025
Powered by FUDForum. Page generated in 0.04418 seconds
