Home » Language IDEs » ServerTools (WTP) » SDO/EMF -> WS
SDO/EMF -> WS [message #142650] |
Thu, 06 October 2005 17:03  |
Originally posted by: v2danc.us.ibm.com
------=_NextPart_000_000A_01C5CA97.D8ADFA00
Content-Type: text/plain;
charset="iso-8859-1"
I like Model Driven Development. I want a Wizard to make the Web =
Service that implements the Model.
I have an EMF ecore model derived from an XML Schema. I can elaborate =
this as generated SDO code.
It seems like WST should know how to make a Web Service from the model =
or the generated classes, with no hand coding on my part, bottom-up. I =
should not have to do the WSDL given that I started from XSD.
Ok, so WST does not know anything about ecore. But, SDOs are Java =
Beans and I have the classes. However, if I do the WS Wizard on a =
root implementation Java class from my elaborated model, I get an error=20
IWAB0521E Failed to analyze the Java bean: =
oem.edge.cq.impl.InfoUsrTypeImpl.=20
The Web Service is not generated. Not much help given.
Perhaps I need to wrap my root implement class as a simpler bean that =
just handles XML Resource output of the class??? =20
However, if that is a needed transformation from ecore to WS, then =
really I expect the Wizard to handle it, to do any wrapping needed, =
without coding on my part.
Dan Connelly
Prosoft Technologies, Inc. (Vermont)
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1515" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>I like Model Driven =
Development. =20
I want a Wizard to make the Web Service that implements the =
Model.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I have an EMF ecore model derived from =
an XML=20
Schema. I can elaborate this as generated SDO=20
code.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>It seems like WST should know how to =
make a Web=20
Service from the model or the generated classes, with no hand coding on =
my part,=20
bottom-up. I should not have to do the WSDL given that I =
started=20
from XSD.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Ok, so WST does not know anything about =
ecore. But, SDOs are Java Beans and I have the=20
classes. However, if I do the WS Wizard on a root=20
implementation Java class from my elaborated model, I get an error =
</FONT></DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV><FONT face=3DArial size=3D2>IWAB0521E Failed to analyze the Java =
bean:=20
oem.edge.cq.impl.InfoUsrTypeImpl. </FONT></DIV></BLOCKQUOTE >
<DIV dir=3Dltr><FONT face=3DArial size=3D2>The Web Service is not=20
generated. Not much help given.</FONT></DIV>
<DIV dir=3Dltr><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV dir=3Dltr><FONT face=3DArial size=3D2>Perhaps I need to wrap my =
root implement=20
class as a simpler bean that just handles XML Resource output of the=20
class??? </FONT></DIV>
<DIV dir=3Dltr><FONT face=3DArial size=3D2>However, if that is a needed =
transformation=20
from ecore to WS, then really I expect the Wizard to handle it, to do =
any=20
wrapping needed, without coding on my part.</FONT></DIV>
<DIV dir=3Dltr><FONT face=3DArial size=3D2> =
Dan=20
Connelly</FONT></DIV>
=20
Prosoft Technologies, Inc. (Vermont)</FONT></DIV></BODY></HTML>
------=_NextPart_000_000A_01C5CA97.D8ADFA00--
Re: SDO/EMF -> WS [message #142671 is a reply to message #142650] |
Thu, 06 October 2005 19:11   |
Originally posted by: thisisnot.mymail.com
The WTP and Eclipse platforms makes it possible for other IDE developers
to do such a thing but I don't believe they will implement such a
feature, but it's something I'd like to see too :)
> Dan Connelly
Re: SDO/EMF -> WS [message #143564 is a reply to message #142650] |
Fri, 14 October 2005 03:02   |
Dan, I'm not sure I've understood exactly what you want but it doesn't
sound too far out. Please open bugizilla bugs to log enhancement
requests and provide a bit more detail and description.
> I like Model Driven Development. I want a Wizard to make the Web Service
that implements the Model. I have an EMF ecore model derived from an XML
Schema. I can elaborate this as generated SDO code.
We're considering future work to provide better support for various code
generation options from XML Schema (including SDO, XBeans etc). So
XSD->SDO is definitely a realistic thing to ask for.
> It seems like WST should know how to make a Web Service from the model or
the generated classes, with no hand coding on my part, bottom-up. I should
Well it's hard to make a web service without a WSDL or some other
description of the operations. One could certainly generate Java code to
represent the data structures directly from XSD. Having bean generators
that run directly from XSD is another valid request to make.
> Ok, so WST does not know anything about ecore. But, SDOs are Java Beans
and I have the classes. However, if I do the WS Wizard on a root
Sounds like you want our generated Web Services to support SDO flavoured
Java Beans. Anothergood enhancement request. There's also ways you can
hack the generated webservices code to make it work with SDOs. I'll leave
it to the folks who handle the Web Services code generation to explain
this though. Open a bugzilla bug to ask for a tutorial on how to do this.
At the very least someone should attach some some sample code to the bug.
> Perhaps I need to wrap my root implement class as a simpler bean that just
> However, if that is a needed transformation from ecore to WS, then really I
expect the Wizard to handle it, to do any wrapping needed, without coding on
my part.
Driving the Web Services generators from ECore is definitely possible. I
can't say we have any plans today to use something other than WSDL to
describe the Web Service operations... but ECore would be another
candidate.
Say, if you're going to write some code to make some of these things work,
perhaps you'd like to contribute it to WTP or lend us a hand in
implementing some of these features in WTP 1.5?
thanks for participating
Re: SDO/EMF -> WS [message #143614 is a reply to message #143564] |
Fri, 14 October 2005 07:48  |
--------------060001030006020504030405
Craig,
You're right. Just as EMF can convert XSD -> Ecore (-> SDO) -> Java
using just enough annotations on the Ecore to be able to read and write
instances of the original XSD, I could imagine having WSDL -> Ecore (->
SDO) -> Java, again with just enough annotations on the Ecore to be able
to produce a web service. And just as 93194
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=93194> supports an
improved Ecore -> XSD, one might support Ecore -> WSDL in a similar
way. Since one can produce Ecore from annotated Java, this could even
help support Java -> Ecore -> WSDL. And since EMF supports dynamic
models, it might even be possible to support all this and not generate
any code at all. Quite the imagination I have hey? ;-)
> XML Schema. I can elaborate this as generated SDO code.
> code generation options from XML Schema (including SDO, XBeans etc).
> So XSD->SDO is definitely a realistic thing to ask for.
>> model or
> to represent the data structures directly from XSD. Having bean
> generators that run directly from XSD is another valid request to make.
>> Beans
> flavoured Java Beans. Anothergood enhancement request. There's also
> ways you can hack the generated webservices code to make it work with
> SDOs. I'll leave it to the folks who handle the Web Services code
> generation to explain this though. Open a bugzilla bug to ask for a
> tutorial on how to do this. At the very least someone should attach
>> just
>> really I
> coding on my part.
> possible. I can't say we have any plans today to use something other
> than WSDL to describe the Web Service operations... but ECore would be
> another candidate.
> work, perhaps you'd like to contribute it to WTP or lend us a hand in
<html>
<head>
http-equiv="Content-Type">
</head>
Craig,<br>
<br>
You're right.
Current Time: Sat Jul 26 19:45:56 EDT 2025
Powered by FUDForum. Page generated in 0.26859 seconds
