Home » Newcomers » Newcomers » rmic stub compiler?
rmic stub compiler? [message #142569] Fri, 10 March 2006 11:18 Go to next message
Is there an easy way to access the rmic stub compiler from within Eclipse?
Charlie
Re: rmic stub compiler? [message #142581 is a reply to message #142569] Fri, 10 March 2006 11:18 Go to previous messageGo to next message
Use the power of Ant:
http://ant.apache.org/manual/CoreTasks/rmic.html
HTH
Darins
"Charlie Kelly" <Eclipse@CharlieKelly.com> wrote in message
news:14cea0ffd0823f191672c8f4d23bc9d5$1@www.eclipse.org...
> Thanks
> Charlie
Re: rmic stub compiler? [message #152361 is a reply to message #142581] Fri, 12 May 2006 18:34 Go to previous message
If you don't want to mess with ant build files, you can use the RMI
Plugin for Eclipse - http://www.genady.net/rmi/v16/
Genady Beryozkin
> HTH
> Darins
>> Thanks
>> Charlie
Previous Topic:View tooltips
Next Topic:Console output disappeared for Ant
Current Time: Mon Nov 10 19:52:29 EST 2025
Powered by FUDForum. Page generated in 0.07365 seconds
