Home » Archived » BIRT » Getting Charts to line up vertically
Getting Charts to line up vertically [message #142331] Thu, 09 March 2006 14:37 Go to next message
Originally posted by: mikewulkan.flyingmoose.ca
I have several charts that I would like to have line up vertically. The X
axis is the same so it scales correctly, however the differing values for
the Y Axis cause the Y Axis of each chart not to line up exactly because
BIRT automatically sizes the area for the Y Axis values according to the
minimum it can get away with. Is there any way to force the Y Axis value
area to a specified width or is there some other way to acheive this
alignment?
Mike
Re: Getting Charts to line up vertically [message #142563 is a reply to message #142331] Fri, 10 March 2006 03:46 Go to previous messageGo to next message
If you use 2.1M5, there is a fix for that: you are now able to specify the
width hint and height hint of the plot. If you're talking about the Y
values, you can set a Y Max on the Y Axis scale. Is that your question?
David
"Mike Wulkan" <mikewulkan@flyingmoose.ca> wrote in message
news:duq06g$7rk$1@utils.eclipse.org...
> alignment?
> Mike
Re: Getting Charts to line up vertically [message #142779 is a reply to message #142563] Fri, 10 March 2006 09:14 Go to previous messageGo to next message
At the moment I have to use 2.0RC2 for some technical reasons.
I'm not sure if this does answer my question? A picture would sure be worth
a thousand words here, but here goes:
I have two charts, one above the other. I'd like the Y axis lines to line
up. They don't because the scales on each Y axis are different and thus
have different max values. BIRT sizes the area required to display the Y
axis values automatically so I can't see how I can get the Y axis lines to
line up short of formating the Y axis values with leading zeros to pad them
all to the same width! Eg.,
10 |
5 |
0 |
1000 |
500 |
0 |
I'd like to see:
10 |
5 |
0 |
1000 |
500 |
0 |
Mike
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:duredg$bqp$1@utils.eclipse.org...
> David
> > Hi,
X
for
value
> > alignment?
> > Thanks,
> > Mike
Re: Getting Charts to line up vertically [message #143124 is a reply to message #142779] Fri, 10 March 2006 17:39 Go to previous message
That seems difficult to do, even with the new plot control I am not sure it
will work. What you can try is show the Y value on the right of the axis and
put your axis on the right of the chart. Not very nice, but it should work.
Another way is to format the number with a space prefix so 10 would become
__10, it's worth a try.
David
news:dus1mg$cul$1@utils.eclipse.org...
> worth
> them
> 10 |
> 5 |
> 0 |
> 1000 |
> 500 |
> 0 |
> I'd like to see:
> 10 |
> 5 |
> 0 |
> 1000 |
> 500 |
> 0 |
> Mike
>> the
>> Thanks,
>> David
>> > Hi,
>> > The
> X
> for
>> > because
>> > the
> value
>> > alignment?
>> > Thanks,
>> > Mike
Previous Topic:How to get report list?
Next Topic:Loading images from XML source
Current Time: Wed Nov 05 22:12:47 EST 2025
Powered by FUDForum. Page generated in 0.03783 seconds
