Home » Archived » Visual Editor (VE) » Error trying to set new file into editor
Error trying to set new file into editor [message #142259] Tue, 23 October 2007 21:36 Go to next message
Originally posted by: andreiberi.look.ca
I am trying to run VE 1.3.0 build on Eclipse 3.3.1 and I am getting the
following error while trying to open a visual class:
"Error trying to set new file into editor. Reason:
java.lang.NullPointerException".
I googled it and it turns out that other people experienced the same
problem on earlier versions of VE.
Anybody has any ideas how to get around this problem?
Andrei
Re: Error trying to set new file into editor [message #142269 is a reply to message #142259] Wed, 24 October 2007 06:03 Go to previous messageGo to next message
Please give more information such as stacktrace or a test-case ! It is hard
to guess what is wrong.
Best regards
Yves YANG
eFace: XAML for java (http://www.soyatec.com)
"Andrei Beri" <andreiberi@look.ca> wrote in message
news:ffm7ia$c8r$1@build.eclipse.org...
> Andrei
Re: Error trying to set new file into editor [message #142279 is a reply to message #142269] Wed, 24 October 2007 23:26 Go to previous messageGo to next message
I cleaned all projects and the problem went away. However it is
reoccurring intermittently.
What are the current plans for releasing official 1.3 version of VE?
Here is the stack trace of the exception:
!ENTRY org.eclipse.ve.java.core 2 0 2007-10-24 22:09:09.609
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.java.codegen.java.AbstractContainerA ddDecoderHelper.getIndexedEntries(AbstractContainerAddDecode rHelper.java:410)
org.eclipse.ve.internal.swt.codegen.CompositeAddDecoderHelpe r.getIndexPriority(CompositeAddDecoderHelper.java:502)
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderH elper.getPriorityOfExpression(ExpressionDecoderHelper.java:1 38)
org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.determinePriority(AbstractExpressionDecoder.java:67)
org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .getPriority(CodeExpressionRef.java:182)
org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.add ExpressionToSortedList(CodeMethodRef.java:604)
org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.sor tExpressions(CodeMethodRef.java:702)
org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.upd ateExpressionOrder(CodeMethodRef.java:710)
org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createFromJVEModel(ExpressionRefFactory.java:109)
org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createInitExpression(ExpressionRefFactory.java:74)
org.eclipse.ve.internal.java.codegen.util.AbstractMethodText Generator.createInitExpression(AbstractMethodTextGenerator.j ava:300)
org.eclipse.ve.internal.java.codegen.util.AbstractMethodText Generator.generateInLine(AbstractMethodTextGenerator.java:31 7)
org.eclipse.ve.internal.java.codegen.java.BeanPartFactory.ge nerateLocalVariable(BeanPartFactory.java:78)
org.eclipse.ve.internal.java.codegen.java.BeanPartFactory.cr eateFromJVEModel(BeanPartFactory.java:670)
org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.laz yCreateBeanInstance(BeanDeclModel.java:305)
org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.get ABean(BeanDeclModel.java:324)
org.eclipse.ve.internal.java.codegen.java.ChildRelationshipD ecoderHelper.getCurrentAddedPart(ChildRelationshipDecoderHel per.java:251)
org.eclipse.ve.internal.java.codegen.java.ChildRelationshipD ecoderHelper.generate(ChildRelationshipDecoderHelper.java:50 1)
org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.generate(AbstractExpressionDecoder.java:194)
org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .generateSource(CodeExpressionRef.java:361)
org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createFromJVEModel(ExpressionRefFactory.java:102)
org.eclipse.ve.internal.java.codegen.java.BeanDecoderAdapter .setElement(BeanDecoderAdapter.java:245)
org.eclipse.ve.internal.java.codegen.java.BeanDecoderAdapter .notifyChanged(BeanDecoderAdapter.java:458)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSe ttingDelegateSingleEObject.dynamicSet(EStructuralFeatureImpl .java:2425)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:1116)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1090)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
org.eclipse.ve.internal.cde.commands.ApplyAttributeSettingCo mmand.execute(ApplyAttributeSettingCommand.java:70)
org.eclipse.ve.internal.propertysheet.common.commands.Compou ndCommand.execute(CompoundCommand.java:224)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack$1.run(JavaVisualEditorCommandStack.java:55)
org.eclipse.ve.internal.cde.core.ModelChangeController.doMod elChanges(ModelChangeController.java:245)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack.execute(JavaVisualEditorCommandStack.java:5 2)
org.eclipse.ve.internal.swt.GridLayoutComponentPage.execute( GridLayoutComponentPage.java:866)
org.eclipse.ve.internal.swt.GridLayoutComponentPage$GrabActi on.run(GridLayoutComponentPage.java:470)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$4.handleEven t(ActionContributionItem.java:375)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Andrei
> Best regards
> Yves YANG
>> Thanks,
>> Andrei
Re: Error trying to set new file into editor [message #142334 is a reply to message #142279] Thu, 25 October 2007 13:49 Go to previous message
Thru the stacktrace, I cannot figure out how this case occurs. I will be
helpful if you can post a testcase.
Yves YANG
news:ffp2ci$rk3$1@build.eclipse.org...
>I cleaned all projects and the problem went away. However it is reoccurring
>intermittently.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrei
>> hard to guess what is wrong.
>> Best regards
>> Yves YANG
>>> Thanks,
>>> Andrei
Re: Error trying to set new file into editor [message #616800 is a reply to message #142259] Wed, 24 October 2007 06:03 Go to previous message
Best regards
Yves YANG
> Andrei
Re: Error trying to set new file into editor [message #616801 is a reply to message #142269] Wed, 24 October 2007 23:26 Go to previous message
!STACK 0
Andrei
> Best regards
> Yves YANG
>> Thanks,
>> Andrei
Re: Error trying to set new file into editor [message #616806 is a reply to message #142279] Thu, 25 October 2007 13:49 Go to previous message
Yves YANG
>intermittently.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrei
>> Best regards
>> Yves YANG
>>> Thanks,
>>> Andrei
Previous Topic:Visual Editor 1.2 not usable in Eclipse 3.2.2
Next Topic:Read this code VE why not support it?
Current Time: Sat Jul 26 12:36:11 EDT 2025
Powered by FUDForum. Page generated in 0.10165 seconds
