Home » Language IDEs » Java Development Tools (JDT) » cvs 1.11.5: "The server did not provide any additional information"
cvs 1.11.5: "The server did not provide any additional information" [message #142172] Mon, 16 February 2004 04:57 Go to next message
I see the error message in the subject when I try to do an "compare with
...." against an CVS 1.11.5 on a Solaris 9 Sparc.
It ran fine against CVS 1.11.1p1 on Linux
The log file says:
"!ENTRY org.eclipse.team.cvs.ui 4 0 Feb 16, 2004 10:56:25.765
!MESSAGE The server did not provide any additional information.
!STACK 1
org.eclipse.team.internal.ccvs.core.connection.CVSServerExce ption: The
server reported an error while performing the "cvs log" command.
org.eclipse.team.internal.ccvs.core.resources.RemoteFile.get LogEntries(RemoteFile.java:266)
org.eclipse.team.internal.ccvs.ui.actions.CompareWithRevisio nAction$2.run(CompareWithRevisionAction.java:76)
org.eclipse.team.internal.ccvs.ui.repo.RepositoryManager.run (RepositoryManager.java:809)
org.eclipse.team.internal.ccvs.ui.actions.CVSAction$1.run(CV SAction.java:242)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
!ENTRY org.eclipse.team.cvs.core 4 -10 Feb 16, 2004 10:56:25.765
!MESSAGE The server reported an error while performing the "cvs log"
command.
!SUBENTRY 1 org.eclipse.team.cvs.core 4 -10 Feb 16, 2004 10:56:25.765
!MESSAGE The server did not provide any additional information."
I have the problem both with Eclipse 2.1.2 and Eclipse 3.0 M7.
I found a bug on eclipse.org that there are problems with CVS servers in
Eclipse 2.1.x but not in the 3.0 stream. So it can't be this problem,
can it?
Does anyone have an advice?
Christoph
Re: cvs 1.11.5: "The server did not provide any additional information" [message #142277 is a reply to message #142172] Mon, 16 February 2004 09:24 Go to previous message
I found the error.
I copied my cvs repository from one machine to another and forgot to
adjust the file permissions for the repository on the new machine.
No error with the cvs version or eclipse, sorry.
Christoph
Previous Topic:Novice: how to compile a Java file w/o creating a project?
Next Topic:blue boxes?
Current Time: Tue Jul 22 00:49:41 EDT 2025
Powered by FUDForum. Page generated in 0.19255 seconds
