Home » Language IDEs » Java Development Tools (JDT) » ant can't find javax.xml.transform when run from inside eclipse
| ant can't find javax.xml.transform when run from inside eclipse [message #141835] |
Fri, 13 February 2004 18:07  |
Originally posted by: rtayek.no.spam.freightgate.com
hi, have a build.xml which runs fine from the command line on windoze xp
and on deadrat's fedora (both with CLASSPATH=""). the app runs fine in
eclsipe (3.0.0 Build id: 200308281813), and the unit tests run fine in
eclipse as apps and as junit tests. but i get a: compile: [javac] Compiling
16 source files to U:\projects\mappingtools\build\classes\srcobj
[javac]
U:\projects\mappingtools\src\com\ediidea\mappingtools\Mappin gTools.java:10:
cannot resolve symbol
[javac] symbol : class TransformerException
[javac] location: package transform
[javac] public static void csvToTransformedXml(final Reader csv,final Reader
xslt,final File intermediate,final Writer xml,final String
lineSeparator,final boolean discardBlankLines) throws
javax.xml.transform.TransformerException, IOException { ...
when running ant from with in eclipse (sorry about the color, i am new to
this brain damaged outlook).
i am using 1.3 as a target, naict, everything in eclipse is ponting to that.
there is no xml apis, xerces or other jars in jre/lib or jre/lib/ext. but
ant has xerces impl and xml apis jars in his lib, so he finds them when run
from the command line. but seems like for some reason, ant can't find the
stuff in his own lib when run from within eclipse? or maybe i am just
confused :(
anybody got a clue?
thanks
<!-- note: you *must* have a copy of junit.jar in ant.home/lib to run the
junit task! -->
<project basedir="." default="all" name="mappingtools">
<property environment="env"/>
<property file="${user.home}/build.properties"/>
<property file="build.properties"/>
<target name="init">
</target>
<target name="clean" depends="init" description="clean">
<delete dir="dist"/>
<delete dir="build"/>
<delete dir="doc/apidoc"/>
<delete dir="deleted"/>
</target>
<target name="compile" depends="init" description="compile">
<mkdir dir="build"/>
<mkdir dir="build/classes"/>
<mkdir dir="build/classes/srcobj"/>
<javac debug="true" deprecation="true" destdir="build/classes/srcobj"
srcdir="src">
<classpath>
<pathelement location="lib/ostermillerutils_1_02_21.jar"/>
</classpath>
</javac>
<mkdir dir="build/classes/srcobj/com/ediidea/mappingtools/files"/ >
<copy todir="build/classes/srcobj/com/ediidea/mappingtools/files" >
<fileset dir="src/com/ediidea/mappingtools/files" includes="*.*"
excludes="*_.* *.nbattrs"/>
</copy>
</target>
<target name="compiletst" depends="compile" description="compile tests">
<mkdir dir="build/classes/tstobj"/>
<javac debug="true" deprecation="true" destdir="build/classes/tstobj"
srcdir="tst">
<classpath>
<pathelement location="${ant.home}/lib/junit.jar"/>
<pathelement location="build/classes/srcobj"/>
</classpath>
</javac>
<mkdir dir="build/classes/tstobj/com/ediidea/mappingtools/testfiles "/>
<copy todir="build/classes/tstobj/com/ediidea/mappingtools/testfiles ">
<fileset dir="tst/com/ediidea/mappingtools/testfiles" includes="*.*"
excludes="*.nbattrs"/>
</copy>
</target>
<target name="jar" depends="init,compile" description="jar">
<mkdir dir="build/lib"/>
<jar basedir="build/classes/srcobj" compress="true"
jarfile="build/lib/mappingtools.jar">
<exclude name="**/deleted/**"/>
<exclude name="**/RCS/**"/>
<exclude name="*.class"/><!-- exclude default package classes-->
</jar>
</target>
<target name="all" depends="init,compile">
</target>
<target name="test" depends="init,compiletst" description="test">
<java classname="com.ediidea.mappingtools.MappingToolsTestCase"
failonerror="true" fork="true">
<classpath>
<pathelement location="${ant.home}/lib/xercesImpl.jar"/>
<pathelement location="lib/xalan.jar"/>
<pathelement location="build/classes/tstobj"/>
</classpath>
</java>
</target>
<target name="testjar" depends="init,jar,compiletst" description="test
jar">
<classpath>
<pathelement location="build/lib/mappingtools.jar"/>
</classpath>
</java>
</target>
<target name="junit" depends="init,jar,compiletst" description="test jar
using junit">
<junit printsummary="true" haltonfailure="true">
<formatter type="plain" usefile="false"/>
<test name="com.ediidea.mappingtools.MappingToolsTestCase"/>
<classpath>
</classpath>
</junit>
</target>
<target name="javadoc" depends="init" description="javadoc">
<mkdir dir="doc/apidoc"/>
<javadoc destdir="doc/apidoc" packagenames="com.ediidea.mappingtools.*">
<sourcepath>
<pathelement location="src"/>
</sourcepath>
<classpath>
<pathelement location="${ant.home}/lib/xml-apis.jar"/>
</classpath>
</javadoc>
</target>
</project>
| Re: ant can't find javax.xml.transform when run from inside eclipse [message #141845 is a reply to message #141835] |
Fri, 13 February 2004 18:29   |
Which Ant are you specifying Eclipse to use...the default ant home which is
in the org.apache.ant plugin which has no Xerces or are you pointing to your
external install that has the xerces JARs?
Darins
"Ray Tayek" <rtayek.no@spam.freightgate.com> wrote in message
news:c0jksl$ia$1@eclipse.org...
Compiling
> [javac]
Reader
that.
run
> confused :(
> anybody got a clue?
> thanks
> junit task! -->
> </target>
> </target>
> srcdir="src">
> <classpath>
> </classpath>
> </javac>
> </copy>
> </target>
> srcdir="tst">
> <classpath>
> </classpath>
> </javac>
> <copy
> </copy>
> </target>
> </jar>
> </target>
> </target>
> <classpath>
> </classpath>
> </java>
> </target>
> jar">
> <classpath>
> </classpath>
> </java>
> </target>
> using junit">
> <classpath>
> </classpath>
> </junit>
> </target>
> <sourcepath>
> </sourcepath>
> <classpath>
> </classpath>
> </javadoc>
> </target>
> </project>
| Re: ant can't find javax.xml.transform when run from inside eclipse [message #142430 is a reply to message #141845] |
Mon, 16 February 2004 18:24  |
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c0jm7d$1mu$1@eclipse.org...
is
your
ant and optional jars that are specified in the ant runtime are from the
3.0/plugins.
but i was working on the project over the weekend (i took it home and hacked
at it). my problem seems to be fixed and now i am stuck with:
BUILD FAILED: file:U:/projects/mappingtools/build.xml:77: Could not create
task or type of type: junit.
despite the fact that i have junit.jar in the ant run time :( - i guess i
will try reproduce this on a simpler project.
thanks
> Darins
xp
> Compiling
> > [javac]
> > [javac] symbol : class TransformerException ...
> > when running ant from with in eclipse ...
> that.
but
> run
the
> > stuff in his own lib when run from within eclipse?...
Current Time: Sun Nov 09 03:11:17 EST 2025
Powered by FUDForum. Page generated in 0.02964 seconds
