Home » Eclipse Projects » Eclipse Platform » NoClassDefFoundError
NoClassDefFoundError [message #141738] Thu, 09 October 2003 09:46 Go to next message
Originally posted by: emmanuel.boudrant.free.fr
I've hot two plugin A and B, B depends on A.
When I activate B, I've got a NoClassDefFoundError :
java.lang.NoClassDefFoundError: com/foo/plugin/core/model/Model
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find Class(DelegatingURLClassLoader.java:922)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:166)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:485)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
at java.lang.Class.getConstructor0(Class.java:1922)
at java.lang.Class.getConstructor(Class.java:1019)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:709)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:130)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:158)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:155)
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(PerspectiveDescriptor.java:98)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:653)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:278)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:177)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:965)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:617)
at org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:609)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2705)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2703)
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMenu.java:58)
at org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:331)
org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveM enu.java:346)
org.eclipse.ui.actions.PerspectiveMenu$4.widgetSelected(Pers pectiveMenu.java:118)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
com/foo/plugin/core/model/Model is owned by plugin A.
Any idea ?
Thx,
-emmanuel
Re: NoClassDefFoundError [message #141783 is a reply to message #141738] Thu, 09 October 2003 11:07 Go to previous message
My mistake is I forgot to export my lib :
<runtime>
<library name="xtreme-core.jar">
<export name="*"/> <<<<HERE
</library>
</runtime>
-emmanuel
eboudrant wrote:
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any idea ?
> Thx,
> -emmanuel
Previous Topic:adding data files to classpath
Next Topic:webtools project status ?
Current Time: Sat Jul 12 10:03:14 EDT 2025
Powered by FUDForum. Page generated in 0.06228 seconds
