Home » Archived » DSDP » Installing eRCP 1.1
Installing eRCP 1.1 [message #13012] Tue, 21 August 2007 15:23 Go to next message
Originally posted by: eclipsedev.lycos.com
I am a newbie to Eclipse and have downloaded and installed Eclipse 3.3 and
the C/C++ IDE (CDT) successfully. I am not sure how to install eRCP 1.1
though. I downloaded and extracted the associated javadocs. The
instructions state to extract to a folder, which I did. I attempted to
install the folder plug-in contents via the Eclipse 3.3 workbench (IDE)
and this appears to have worked, but I am not sure. Is there a reference
link or can someone explain what actually needs to be done to install eRCP
1.1 correctly? I guess I was expecting to see something from the eRCP
contents in the Eclipse 3.3 "New Project Wizard" (which I don't). I am
mainly interested in C\C++ development using Eclipse. Thanks.
johncw
Re: Installing eRCP 1.1 [message #13075 is a reply to message #13012] Fri, 24 August 2007 16:41 Go to previous messageGo to next message
Hello John,
When I'm not mistaken, eRCP is really a target platform for your PDE
toolkit. So, the simplest way to test it, is:
* Download eRCP for Windows
- Extract to a directory, you can launch the sample
apps via batchfile right away.
* Launch Eclipse SDK on a new workspace
* Window > Preferences > Plug-In Development > Target Platform
and navigate to the eRCP installation (just above the plugins dir)
Now you can start writing applications against the eRCP platform.
I don't think there are any special wizards, because you just write
normal plug-ins just as with PDE -- only you write it against the
limited set of APIs from eRCP.
I'm also forwarding your message to the relevant eRCP newsgroup and
mailing list.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
johncw wrote:
> and the C/C++ IDE (CDT) successfully. I am not sure how to install eRCP
> 1.1 though. I downloaded and extracted the associated javadocs. The
> eRCP 1.1 correctly? I guess I was expecting to see something from the
> eRCP contents in the Eclipse 3.3 "New Project Wizard" (which I don't). I
> am mainly interested in C\C++ development using Eclipse. Thanks.
> johncw
Re: Installing eRCP 1.1 [message #13103 is a reply to message #13075] Wed, 29 August 2007 10:54 Go to previous message
Thank you.
Re: Installing eRCP 1.1 [message #571427 is a reply to message #13012] Fri, 24 August 2007 16:41 Go to previous message
Hello John,
mailing list.
Martin Oberhuber
johncw wrote:
> johncw
Re: Installing eRCP 1.1 [message #571467 is a reply to message #13075] Wed, 29 August 2007 10:54 Go to previous message
Thank you.
Previous Topic:DSDP-TM is Eclipse BugDay Featured Project of the month August!
Next Topic:Eclipse Summit Europe - Embedded and Mobile Symposium
Current Time: Mon Jul 14 03:50:31 EDT 2025
Powered by FUDForum. Page generated in 0.28979 seconds
