Home » Eclipse Projects » Remote Application Platform (RAP) » StackPresentation is not coupled with PartId
Re: StackPresentation is not coupled with PartId [message #141335 is a reply to message #141218] |
Thu, 23 July 2009 05:04   |
Hi! Thank you it helped me a lot. I'm going to illustrate with some pieces
of code the mistake I was making, so that no one gets confused in the
future:
My code before (No coupling between StackPresentation id and Part id) :
public class Perspective implements IPerspectiveFactory
public void createInitialLayout(IPageLayout layout)
String editorArea = layout.getEditorArea();
layout.setEditorAreaVisible(false);
layout.addStandaloneView(TopView.ID, false, IPageLayout.TOP, 0.2f,
editorArea);
layout.addStandaloneView(BottomView.ID, false, IPageLayout.BOTTOM,
0.8f, editorArea);
layout.getViewLayout(NavigationView.ID).setCloseable(false);
layout.getViewLayout(NavigationView.ID).setMoveable(false);
layout.getViewLayout(BottomView.ID).setCloseable(false);
layout.getViewLayout(BottomView.ID).setMoveable(false);
My code now (Coupling between StackPresentation id and Part id is working)
IFolderLayout topFolder = layout.createFolder("topViewLayout",
IPageLayout.TOP, 0.2f, editorArea);
topFolder.addView(TopView.ID);
IFolderLayout bottomFolder = layout.createFolder("bottomViewLayout",
IPageLayout.BOTTOM, 0.8f, editorArea);
bottomFolder.addView(BottomView.ID);
Since I'm using Standalone Views, I did not see the point of creating a
IFolderLayout to stack one unique Standalone View. But I realize that it
is necessary to create a IFolderLayout if you want to couple a
StackPresentation id with a Partid (in this example the Partids are:
"topViewLayout" and "bottomViewLayout"), since the Partid used for the
coupling is actually the name given to this IFolderLayout (before that I
thought it was the id of the View itself). The coupling is done in the
branding extension point (cf. the article "RAP Look and Feel").
I hope this helps.
Thank you again Holger,
Jordan
Re: StackPresentation is not coupled with PartId [message #141342 is a reply to message #141335] |
Thu, 23 July 2009 05:29   |
Hi Jordan,
nice to here it's working now and thanks for providing the snippets,
this is great for other users of the API. If you have completed your
StackPresentation it would be nice to see it. So maybe you can provide
a Screenshot to us ;)
Regards Holger
> pieces of code the mistake I was making, so that no one gets confused
> in the future:
> public class Perspective implements IPerspectiveFactory {
> editorArea);
> 0.8f, editorArea);
> My code now (Coupling between StackPresentation id and Part id is working) :
> layout.createFolder("bottomViewLayout", IPageLayout.BOTTOM, 0.8f,
> editorArea);
> it is necessary to create a IFolderLayout if you want to couple a
> I thought it was the id of the View itself). The coupling is done in
> the branding extension point (cf. the article "RAP Look and Feel").
> I hope this helps.
> Jordan
http://eclipsesource.com
http://twitter.com/eclipsesource
Re: StackPresentation is not coupled with PartId [message #141352 is a reply to message #141342] |
Thu, 23 July 2009 08:03  |
Hi Holger,
You're welcome for the snippets, it is totally normal. I will definitely
post a screenshot (if I find out how to post an image on the NewsPortal
lol) once it is done, and I will explain how I managed to get that result.
For the moment, I still have to find out how to get rid of these three
pixels that separate my two views.
Jordan
> Hi Jordan,
> Regards Holger
>> in the future:
>> editorArea);
>> 0.8f, editorArea);
>> editorArea);
>> I hope this helps.
>> Jordan
Current Time: Sat Jun 21 08:50:37 EDT 2025
Powered by FUDForum. Page generated in 0.25887 seconds
