Home » Language IDEs » C / C++ IDE (CDT) » Configuration - CDT and Cygwin
| Configuration - CDT and Cygwin [message #140910] |
Tue, 15 March 2005 18:56  |
Originally posted by: me.my.com
I've seen my problem posed in many places, and various answers given, some
of which worked for the OP but that don't for me.
I've installed the Eclipse Platform SDK 3.0.1 on a Win98 machine that has
Cygwin installed. Over this I've added CDT 2.1.
I've set up my C:\Cygwin\bin in first spot on my path in my autoexec.bat
file (remember those? ;-)). Cygwin all works fine from a shell - MSDos or
BASH - however, no matter how many - and I mean many - things I have tried
already, I just can't get Eclipse then to 'see' it on the path.
Everything's where it needs to be on my system, the cygwin bin is on the
path, yet Eclipse falters at startup with 'cygwin1.dll' not found. Then,
when it starts up and I work through creating a managed-make project, it's
no surprise that it fails with errors: echo command not found, rm not
found, that kind of stuff.
It's all there in the bin, however, and the bin's on the path, and . . .
At the moment I'm looking at how bash manages (converts) this path. In
DOS, it starts
PATH=C:\CYGWIN\BIN;C:\WINDOWS;C:\WINDOWS\COMMAND;C:\OLDMSDOS , etc.
Then, from bash, this becomes
PATH='/usr/bin:/cygdrive/c/WINDOWS:/cygdrive/c/WINDOWS/COMMA ND:/cygdrive/c/OLDM
SDOS, etc.
And it seems to be this conversion that is part of the problem. The other
elements of the path /cygdrive/c/Windows all function properly, and I've
been trying to get a way to have the Cygwin bin in the path rendered also
as /cygdrive/c/Cygwin/bin, and I've achieved this in a roundabout way, but
it still doesn't work.
And I can't figure out either how it seems, during a build, to be able to
find make all right, it's just that after that make can find the rest of
the stuff it needs.
This has had well over a week of my time already, and I've just about run
dry of new ideas.
How I wish Eclipse just had a property field where you specified your
Cygwin (etc) path, and that was it.
Any working solution would be gladly received, however much of a
workaround it might be.
Cheers
PB
| Re: Configuration - CDT and Cygwin [message #140921 is a reply to message #140910] |
Tue, 15 March 2005 20:22   |
Originally posted by: ddaoust.ca.ibm.com
In the CDT FAQ it states that CDT will not run on Windows98
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/user/faq.html?cvsroot=Tools_Project#general_60
- Dave
"Shaq" <me@my.com> wrote in message news:d17smg$f26$1@www.eclipse.org...
> DOS, it starts
LDM
> SDOS, etc.
> the stuff it needs.
> dry of new ideas.
> Cheers
> PB
| Re: Configuration - CDT and Cygwin [message #140985 is a reply to message #140910] |
Wed, 16 March 2005 08:18  |
Originally posted by: Serge.Iovleff.univ-lille1.fr
I have the same configuration. I solve partly the problem.
If the first time you want to compile (make all), you have the message "g++ command not found" error...
- save your work, exit the platform
- launch the platform again, compile
- this should work !
If you launch a C/C++ application from the platform, you will experiment a 'cygwin1.dll' not found
the only way I found is to copy the cygwin1.dll in the project.
Serge
> some of which worked for the OP but that don't for me.
> has Cygwin installed. Over this I've added CDT 2.1.
> or BASH - however, no matter how many - and I mean many - things I have
> tried already, I just can't get Eclipse then to 'see' it on the path.
> it's no surprise that it fails with errors: echo command not found, rm
> not found, that kind of stuff.
> DOS, it starts
> SDOS, etc.
> other elements of the path /cygdrive/c/Windows all function properly,
> and I've been trying to get a way to have the Cygwin bin in the path
> rendered also as /cygdrive/c/Cygwin/bin, and I've achieved this in a
> roundabout way, but it still doesn't work.
> to find make all right, it's just that after that make can find the rest
> of the stuff it needs.
> run dry of new ideas.
> Cheers
> PB
Current Time: Sat Nov 08 03:46:44 EST 2025
Powered by FUDForum. Page generated in 0.03887 seconds
