Home » Archived » Visual Editor (VE) » logging the plug-in build from IDE
logging the plug-in build from IDE [message #140769] Thu, 20 September 2007 14:33 Go to next message
Originally posted by: bwcummiskey.tendrilinc.com
Given a project that is used to generate a plug-in and also a product, from
within the IDE
is there a way to turn on logging so that I can see what is being executed
when from the Overview window of the plugin.xml
(please see attached screenshot)
when "Launch an Eclipse Application" or "Export Wizard" is selected and run?
Also, can you enable logging for what happens when you Export a product?
thanks,
Bernie
  • Attachment: eclipse1.png
    (Size: 24.17KB, Downloaded 304 times)
  • Attachment: eclipse2.png
    (Size: 22.01KB, Downloaded 346 times)
Re: logging the plug-in build from IDE [message #140811 is a reply to message #140769] Thu, 20 September 2007 15:43 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Please do not use this newsgroup. This newsgroup is for the Visual
Editor. These questions have nothing to do with the Ve.
> within the IDE
> thanks,
> Bernie
Rich Kulp
Re: logging the plug-in build from IDE [message #616579 is a reply to message #140769] Thu, 20 September 2007 15:43 Go to previous message
> within the IDE
> thanks,
> Bernie
Rich Kulp
Previous Topic:logging the plug-in build from IDE
Next Topic:migrating pdebuid from 3.3m4 to 3.3.0
Current Time: Thu Nov 20 18:32:46 EST 2025
Powered by FUDForum. Page generated in 0.03582 seconds
