Home » Eclipse Projects » Remote Application Platform (RAP) » Is RAP specifically for Eclipse RCP? Can RAP be used/run in Eclipse IDE/workbench/workspace environ
Is RAP specifically for Eclipse RCP? Can RAP be used/run in Eclipse IDE/workbench/workspace environ [message #1065] Mon, 09 October 2006 16:49 Go to next message
I take that it is yes, but just wanted to make sure. Thanks.
Re: Is RAP specifically for Eclipse RCP? Can RAP be used/run in Eclipse IDE/workbench/workspace e [message #1095 is a reply to message #1065] Tue, 10 October 2006 10:11 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
AL,
the RAP project aims to enable developers to build rich, AJAX-enabled
Web applications by using the Eclipse development model, plug-ins and
a Java-only API.
So it is *not* RCP but it will provide an RCP-like programming model
for web applications, including a "web workbench".
I'm not sure that I understood Your question right. Does the above
answer Your question?
-- Rüdiger
Re: Is RAP specifically for Eclipse RCP? Can RAP be used/run in Eclipse IDE/workbench/workspace e [message #1122 is a reply to message #1095] Tue, 10 October 2006 12:28 Go to previous message
Rüdiger Herrmann wrote:
> AL,
> a Java-only API.
> -- Rüdiger
Thanks! So, basically, I cannot have RAP inside of Eclipse, but only
what RAP offers, as mentioned above, that is, OSGI functionality and
Eclipse development model.
Previous Topic:2006-09 v0.2
Next Topic:Java2Script - the SWT to JS.
Current Time: Sat Nov 22 18:06:20 EST 2025
Powered by FUDForum. Page generated in 0.03582 seconds
