| Problem with using TPTP's API Recorder [message #140315] |
Thu, 12 February 2009 10:04  |
I'm very new to using TPTP. And i've got problem with launching my app
with API Recorder agent - JVMPI isn't supported.
I've spent some time on reading news of this group but haven't found out
aswer:
Is there any possibility launch API Recorder agent with Java 1.6?
My configuration:
- Eclipse Platform 3.4.1 running on windows (IA32)
- TPTP Plugin version 4.5.1 (API Recorder version 4.3.0)
- Java 1.6.0_11
Thank you in advance,
Ihor.
| Re: Problem with using TPTP's API Recorder [message #140825 is a reply to message #140626] |
Mon, 02 March 2009 10:52  |
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=266676.
Thanks Ihor for opening this defect.
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:gnmcba$o6p$1@build.eclipse.org...
> Hi Ihor,
> The API Recorder builds on the TPTP ProbeKit, which supports Java 1.6.
> However, after testing this configuration, the API Recorder hangs during
> recording in a Java 1.6 run-time. Please open a TPTP defect
> (Test.Agents.Recorder component) at:
> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
> As a work-around, please use Java 1.5, since this run-time has been tested
> in TPTP 4.5.x.
> Paul
> "Ihor " <ihorko@i.ua> wrote in message
> news:b04f7204d3cbd2bdc5c4b58fa54e8171$1@www.eclipse.org...
>> aswer:
>> My configuration:
>> - Java 1.6.0_11
>> Ihor.
FUDForum. Page generated in 0.02665 seconds
