| Errors Creating Tags [message #12895] |
Mon, 04 February 2008 00:09  |
When I'm creating tags, I sometimes get an 'Tag Operation Failed' error
with the details:-
svn: PUT request failed on
'/svn/easi/!svn/wrk/a9048ae2-1701-0010-b03e-f187d09c0a47/tag s/build__356_hotfix__2/com/easi/ets/ets.fla'
svn: Connection reset by peer: socket write error
But I can't redo the operation because subversive tells me the tag
already exists.
How do I recover when I get this error?
| Re: Errors Creating Tags [message #13322 is a reply to message #13211] |
Wed, 13 February 2008 03:37   |
Alexander Gurov wrote:
> Chris Velevitch wrote:
>> I'm just a bit curious as to why there is a lot on network traffic
>> happening when I add a tag? Isn't tagging more of a server-based
>> activity?
> Yes, but only in case if tag or branch was made from the Repositories
> Explorer view. If you create a tag or a branch from the Package Explorer
> view additional network interaction can happen in case if you commit
> changes in the same transaction or your working copy is not up to date,
> because operation should reflect real state of working copy which
> differs in that case from the repository one.
I've been creating tags from the Navigator View by right clicking the
project root and select Team -> Tag..., I don't use the Package Explorer
view because it's a Java thing and I'm not using Java.
When I commit changes I do it from the Synchronize view and I do
selective synchronize by selecting all the files to sync and
right-clicking the selected files and choosing Commit....
Once I've committed the files, I export the files to build and test my
application, then, when I'm happy it with the build, I tag the current
trunk.
How is it possible to commit changes whilst creating a new tag? If what
you are saying is true, then clearly that's wrong because in the
scenario I've outlined, that will change the trunk and so invalidates
the what the tag is meant to represent.
| Re: Errors Creating Tags [message #13347 is a reply to message #13322] |
Wed, 13 February 2008 03:49  |
There are no difference between Package Explorer and Navigator views -
both works with the same working copy.
Changes are committed in that case not into trunk but into created tag.
I.e. Subversion makes tag which strictly corresponds to current state of
your working copy.
FUDForum. Page generated in 0.05457 seconds
