Home » Language IDEs » ServerTools (WTP) » JSP: double quotes
JSP: double quotes [message #140119] Thu, 22 September 2005 07:55 Go to next message
I have quasetion about double quotes in JSP as in example:
<html:text name="myDate" property="date"
value="<%=request.getParameter("date") %>" />
In Eclipse (3.1 + WTP 0.7) there is no error, but in WSAD 5.1.0 (based
on Eclipse 2.1?) there is error like this: "JspTranslate: Attribute date
has no value". This error is not so clear, but for them, who are
familiar with WSAD error messages, they know, that WSAD claims on double
quotes. It's against JSTL 1.0 specification (the same example is
described in book
http://publib-b.boulder.ibm.com/abstracts/sg246690.html?Open , page
269-272).
On Tomcat there is no problem, but on WAS 5.0.2 it can't run.
Why WTP doesn't complain on that?
Martin
Re: double quotes [message #140268 is a reply to message #140119] Thu, 22 September 2005 11:57 Go to previous messageGo to next message
thats because you have to escape the quotes like that.
value="<%=request.getParameter(\"date\") %>" />
Unfortunately WTP has a bug (104767) and you will get an error indicator
with "Syntax Error on token "Invalid Character" as message.
Klaus
"Maple" <maple@seznam.cz> schrieb im Newsbeitrag
news:dgu67q$pqp$1@news.eclipse.org...
> Hello,
> described in book
> 269-272).
> Martin
Re: JSP: double quotes [message #140280 is a reply to message #140119] Thu, 22 September 2005 12:07 Go to previous messageGo to next message
Originally posted by: erickson_d.yahoo.removethis.com
WTP doesn't complain because it is following the JSP2.0 spec. WSAD is
complaining because it is following the JSP1.2 spec. They differ on
this issue.
The relevant grammar is found on page 1-26 of JSP2.0
RTAttributeValueDouble::=
((QuotedChar - '"' )* - ((QuotedChar - '"')* '%>'))
( '%>"' | <TRANSLATION_ERROR> )
The JSP2.0 grammar says, in English: if the attribute value of a custom
action starts with <%= it must end with %> and any matching quote
symbols in between are ignored.
On the other hand, JSP1.2 doesn't have a formal grammar, but page 41
shows an example with the same form you asked about and says it's illegal.
Decide what JSP version you will use, then pick a servlet engine that
supports it. Tomcat 5 or greater supports JSP2.0. I highly recommend
JSP2.0 for its EL and tag files -- often overlooked gems without which
JSP development is abominable.
Hope that helps,
Doug
Maple wrote:
> Hello,
> described in book
> 269-272).
> Martin
Re: JSP: double quotes [message #140293 is a reply to message #140280] Thu, 22 September 2005 12:28 Go to previous messageGo to next message
Hmm. Let me retract that. I misread the JSP2.0 grammar. It does say
that any matching quotes inside the scriptlet must be quoted with a
backslash. I guess this is a bug in WTP and Tomcat.
Sorry for the confusion!
> this issue.
> Hope that helps,
> Doug
> Maple wrote:
>> Hello,
>> date has no value". This error is not so clear, but for them, who are
>> double quotes. It's against JSTL 1.0 specification (the same example
>> is described in book
>> 269-272).
>> Martin
Re: double quotes [message #140326 is a reply to message #140268] Fri, 23 September 2005 02:00 Go to previous message
Better this error than no error (in this case :-). But in my WTP (0.7) I
can't see no message like "syntax error on token..." WTP doesn't
complain on this.
Martin
Previous Topic:Lost J2EE Perspective
Next Topic:Unknown tag warning in JSPs
Current Time: Tue Nov 04 00:03:15 EST 2025
Powered by FUDForum. Page generated in 0.04367 seconds
