Home » Archived » Test and Performance Tools Platform (TPTP) » OC4J and Agent Controller
OC4J and Agent Controller [message #139971] Thu, 05 February 2009 15:28 Go to next message
Hi:
We're running OC4J on Linux 64-bit with the Java 1.5 packaged with OC4J.
I have setup and run Agent Controller 4.2.0 successfully on the Linux box.
However when I specify -XrunpiAgent:server=enabled or -XrunpiAgent as a
JVM parameter on my OC4J instance, it goes into an unusable state. I
can't undo the JVM parameters and the instance will refuse to start. The
only thing I can do is delete the instance and start over.
I will also post this on Metalink to get Oracle's feedback.
Any help is appreciated.
Eric
Re: OC4J and Agent Controller [message #140003 is a reply to message #139971] Thu, 05 February 2009 17:03 Go to previous message
Hi Eric,
Only 32 bit JVM is supported by the Agent Controller with the pre-JVM 1.5
profiling agent (aka JVMPI agent).
Please try with a 32 bit JVM or use a more latest TPTP version which
supports 64bit JVM. eg. v4.5.1.
Eugene
"Eric Hamacher" <badgerduke@gmail.com> wrote in message
news:060eee4a81c53f4a6d2eb71996b4ecf5$1@www.eclipse.org...
> Hi:
> Eric
Previous Topic:Profiling Standalone Application
Next Topic:Unreleased memory usage after profiling
Current Time: Sat Aug 09 19:06:09 EDT 2025
Powered by FUDForum. Page generated in 0.24080 seconds
