Home » Language IDEs » C / C++ IDE (CDT) » Problem with display of variables and their values in Debug mode
Problem with display of variables and their values in Debug mode [message #139614] Fri, 25 February 2005 17:51 Go to next message
Originally posted by: skahlon.genband.com
I can set breakpoints, step thru the code without any problem. However,
the Variables window only displays a few Classes which are disabled. When
I click the right button and select Enable, I do see the text class name
followed by public and another entry with private. These are disabled,
and this time, the Enable selection is not available in the right click
menu. How can I see the member variables of the class?
Values of many other variables in the source code window can be seen by
doing mouse-over (tooltip), but these variables do not appear in the
Variables window.
How can I get to display all classes, variables, and structures in the
Variables window, along with their values?
Re: Problem with display of variables and their values in Debug mode [message #139739 is a reply to message #139614] Mon, 28 February 2005 14:00 Go to previous message
Originally posted by: mikhailk.qnx.com
Please, submit a bug in Bugzilla, if you have a reproducible test case.
"Satwinder Kahlon" <skahlon@genband.com> wrote in message
news:cvoa4t$i71$1@www.eclipse.org...
>followed by public and another entry with private. These are disabled, and
>this time, the Enable selection is not available in the right click menu.
> Variables window.
Previous Topic:Problems view in Build 2.1?
Next Topic:One project - several applications?
Current Time: Wed Nov 26 08:11:26 EST 2025
Powered by FUDForum. Page generated in 0.03212 seconds
