| Eclipse and Subversion [message #139597] |
Thu, 05 February 2004 20:23  |
Originally posted by: russell.thamm.dsto.defence.gov.au
I have been using NetBeans for Java development and have just tried
Eclipse.
I have been impressed so far but I have a few issues that I can't resolve.
I use Subversion for source version control (no way I'll go back to CVS)
a) Is there any way to get eclipse to ignore .svn directories and contents?
I have added a filter to the Projects Java Build Path (Source). This stops
Eclipse for copying .svn directories to the output directory. However,
Eclipse still shows these "resources" in lots of places eg Resource
Perspective (Navigator view). Worse Eclipse wants to put these resources
into my jar files. (I also have a similar problem with .nbattrs files.)
b) How do I share my workspace/projects between machines (all Windows
machines)?
What files do I need to put under Revision Control to share my WorkSpace
and/or Projects between machines? (For MSVC, I have the Workspace (.dsw)
and Project (.dsp) files under Revision Control.)
Do I need the full contents of the WorkSpace directory (minus bin)?
thanks
Russell Thamm
| Re: Eclipse and Subversion [message #139732 is a reply to message #139689] |
Fri, 06 February 2004 09:12   |
Originally posted by: jrp.thepiersols.com
Michael Legart wrote:
> On Fri, 6 Feb 2004 05:19:05 +0000 (UTC), Jim Piersol <jrp@thepiersols.com>
wrote:
> > have you sold in subversion ? I haven't looked for a while, but last time
> > I did, I ws thinking subversion only had a small set of features and was
> > pretty incomplete. Please school me :>
> Last time you looked must have been 3 years ago then... Subversion is
> very near 1.0 (release this month) and it fixes most of the annoyances
> CVS has... see http://subversion.tigris.org/ for a list of features.
OK, I just had another look. It does appear to be much more complete then
last time I looked. I agree, it has some of the features that I have
always longed for in cvs. Too bad the effort couldn't of been used to
actually improve cvs versus re-inventing the wheel. CVS is so embedded in
the open-source community...and now it is so convienient to use from
IntelliJ and Eclipse that it isn't even funny.
Oh well, maybe someday I will have a need to start a new source control
system, and maybe I will choose subversion. I can't get too excited about
replacing/converting from cvs just yet :>)
Thanks for the info though, that is just what I was after.
| Shared Launch Configs (was: Eclipse and Subversion) [message #141737 is a reply to message #139999] |
Fri, 13 February 2004 07:56  |
Laura Werner wrote:
> Russell Thamm wrote:
>> I have a similar means, subversion. My question still is:
>> what files ?
> You'll need to check in ".classpath" and ".project" in the project's
> top-level directory. If you have any external tools builders, you can
> also check in the contents of ".externalToolsBuilders" (or something
> like that). In addition, you can save your launch configurations to
> disk by making them "shared" configurations and check those in too.
Just a few minutes ago I tried that :). Unfortunately Eclipse defaults
the runtime workspace location to an absolute path. Is there any way to
make that relative to the "normal" workspace? Are there variables to
accomplish that? I tried ${workspace_loc:/../runtime-workspace} but
that created a directory with exactly that name, so no variable
substitution took place.
TIA, Thomas.
Thomas Maier <Thomas.Maier@uni-kassel.de>
FUDForum. Page generated in 0.06379 seconds
