Home » Newcomers » Newcomers » eclipse configuration
eclipse configuration [message #139585] Wed, 22 February 2006 09:09 Go to next message
Originally posted by: d.dodgeit.com
how do you configure eclipses startup routine? I have a external jar file
that I want eclipse to use but if I add it in the java build path in the
preferences under window it still won't find it. If I include it in a
project in the projects build path it will find it and use it in the
runtime workbench. What am I missing?
Re: eclipse configuration [message #140108 is a reply to message #139585] Fri, 24 February 2006 13:18 Go to previous message
There is a workaround for this problem. The jar file I was trying to use
is the mysql-connector-java-3.1.12-bin.jar for connection with JDBC to a
MySQL database on a Linux machine. Instead of including the jar file in
the build path and launching it in the workbench I included the source
code of MySQL connector in the build path and export that and it works.
The source code was all in the com folder of MySQL. I don't know if it
will help but if you can't your functionality out of a JAR file when you
export it in eclipse, try and use the source code folder instead.
Previous Topic:eclipse ant tasks
Next Topic:No clear instructions is annoying
Current Time: Sat Nov 08 12:30:29 EST 2025
Powered by FUDForum. Page generated in 0.08487 seconds
