Unreleased memory usage after profiling [message #139550] |
Wed, 14 January 2009 14:08  |
I am using TPTP 4.5.1 with Eclipse 3.4.1 on Win XP Pro SP2. I notice that
after executing a profiling session (gathering execution statistics), the
heap usage in Eclipse goes up and the memory isn't released with garbage
collection. Therefore, I can only run 1 or 2 (maybe 3) profiling sessions
before I start getting out of memory errors in Eclipse and have to restart
the workbench.
Is this expected behavior? I'm already at 650 MB of heap, don't think I
can go much higher with the amount of RAM I have.
Thanks for reading.
Re: Unreleased memory usage after profiling [message #140013 is a reply to message #139550] |
Thu, 05 February 2009 17:15  |
Hi Gebriel,
There is an action available under the 'Profiling Monitor' view named
'Unload Profiling Data' that enables user to free up the memory used for
profiling data collected. Select an profiling agent for example and right
click for the context menu for the action. When selected, you will be
prompted with an option to save the resource to file as needed before the
data is released from memory, in case you would like to reload the profiling
data later. Keep in mind that you will not be able to view any unsaved data
at a later time.
Eugene
"Gabriel Valencia" <gvalenc@us.ibm.com> wrote in message
news:0d546a370a988fb64f136be337734513$1@www.eclipse.org...
>the workbench.
> Thanks for reading.
FUDForum. Page generated in 0.17206 seconds
