Home » Eclipse Projects » Eclipse Platform » Generics are here (no, not in eclipse)
Generics are here (no, not in eclipse) [message #139524] Fri, 03 October 2003 15:02 Go to next message
I've run across this post
( http://groups.google.com/groups?selm=bl9025%248ef%241%40onli ne.de&oe=UTF-8&output=gplain)
titled: "[ANN] IDE with support for upcoming Java 1.5 language features"
Excerpt:
[CodeGuide fully supports generic types as specified in JSR 14 and all
other language enhancements as specified in JSR 201: enums, varargs,
autoboxing, static imports and the enhanced for loop. Code completion,
compilation and refactorings are aware of the new features.
- Generify refactoring
The Generify refactoring is a powerfull tool which converts old
projects to make use of generic types. The generic parameter types
are infered by CodeGuide by analyzing the existing code of the
whole project. Generification affects variables, fields and classes.
Apparently somebody else is already committed to the idea of generics
and other features. Sadly, this feature is not committed on Eclipse's
3.0 plan (*). I think eclipse is leading in the area of Java IDEs and it
will be really sad to see it losing the lead.
If you want to see generics, enhanced for loops and more 1.5 features
vote for it here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36938
Genady
(*) eclipse plan as of October 4 -
http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_0.html#OtherJDT
Re: Generics are here (no, not in eclipse) [message #139674 is a reply to message #139524] Sat, 04 October 2003 14:54 Go to previous messageGo to next message
> vote for it here:
and that bug has a target of 3.0! (is on the plan list of 3.0)
so it is committed as far as i can see.
johan
Re: Generics are here (no, not in eclipse) [message #139716 is a reply to message #139674] Sat, 04 October 2003 15:46 Go to previous messageGo to next message
In the plan it says "The following work items are being actively
investigated, but we are not yet able to promise any solution for this
release".
Genady
http://www.genady.net/rmi/
>> vote for it here:
> johan
Re: Generics are here (no, not in eclipse) [message #139770 is a reply to message #139716] Sun, 05 October 2003 06:32 Go to previous messageGo to next message
I personally think that they will put it in 3.0
Because they will release 3.0 in Q2 of next year
so 1.5 will be near by then and a follow up (3.1?)
will likely be much later then 1.5.
But generics is still a moving target where are they now in
the version number 2.2?
johan
> release".
> Genady
>>> vote for it here:
>> johan
Re: Generics are here (no, not in eclipse) [message #139781 is a reply to message #139770] Sun, 05 October 2003 07:34 Go to previous message
The plan states this accurately we really want to have 1.5 support in 3.0.
We have reserved time to work on it. However, 1.5 isn't a fixed target and
we cannot commit to a moving target.
--erich
given that 1.5 isn't fully fixed
"Johan Compagner" <jcompagner@j-com.nl> wrote in message
news:blors9$2je$1@eclipse.org...
> johan
> > release".
> > Genady
it
> >>> vote for it here:
> >> johan
Previous Topic:Adding popup menu to "Source" submenu of IJavaProject context menu
Next Topic:[Fwd: CVSProviderPlugin.execProblem]
Current Time: Thu Sep 18 15:54:23 EDT 2025
Powered by FUDForum. Page generated in 0.10177 seconds
