Home » Eclipse Projects » GEF » repopulate palette
repopulate palette [message #139186] Tue, 22 June 2004 02:35 Go to next message
I tried to build a palette view with paletteviewer in a standard eclipse
view.
The problem i faces is that when i have a palette entry selected in that
view and i close the editor. I tried to repopulate the paletteroot and set
it to the palette view. I faced a error message as following. I guess this
is becuase the activeEntry is not be resetted when the palette root was
setted to a new one. Am i right?
i call this method to set the new palette root:
PaletteViewer.setPaletteRoot(root);
org.eclipse.gef.ui.palette.PaletteViewer.setActiveTool(Palet teViewer.java:301)
org.eclipse.gef.internal.ui.palette.editparts.ToolEntryEditP art.removeNotify(ToolEntryEditPart.java:253)
org.eclipse.gef.editparts.AbstractEditPart.removeNotify(Abst ractEditPart.java:885)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.removeNo tify(AbstractGraphicalEditPart.java:691)
org.eclipse.gef.editparts.AbstractEditPart.removeChild(Abstr actEditPart.java:826)
org.eclipse.gef.editparts.GraphicalRootEditPart.setContents( GraphicalRootEditPart.java:160)
org.eclipse.gef.ui.palette.PaletteViewer.setPaletteRoot(Pale tteViewer.java:315)
com.actuate.iard.designer.ui.views.paletteview.PaletteView.r eBuildView(PaletteView.java:56)
com.actuate.iard.designer.ui.mediator.IARDDesignerMediator.r efreshPalette(IARDDesignerMediator.java:55)
com.actuate.iard.designer.ui.mediator.IARDDesignerMediator.s etEditor(IARDDesignerMediator.java:37)
com.actuate.iard.designer.ui.editor.ReportGraphicalEditor.re gisterToMediator(ReportGraphicalEditor.java:280)
com.actuate.iard.designer.ui.editor.ReportGraphicalEditor.di spose(ReportGraphicalEditor.java:294)
org.eclipse.ui.internal.WorkbenchPartReference.dispose(Workb enchPartReference.java:162)
org.eclipse.ui.internal.EditorManager$Editor.dispose(EditorM anager.java:1199)
at org.eclipse.ui.internal.WorkbenchPage$5.run(WorkbenchPage.ja va:1105)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:819)
at org.eclipse.core.runtime.Platform.run(Platform.java:493)
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1103)
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:900)
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:864)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:87 )
org.eclipse.ui.internal.TabbedEditorWorkbook$1.itemClosed(Ta bbedEditorWorkbook.java:132)
at org.eclipse.swt.custom.CTabFolder.closeNotify(CTabFolder.jav a:316)
at org.eclipse.swt.custom.CTabFolder.access$13(CTabFolder.java: 306)
at org.eclipse.swt.custom.CTabFolder$4.handleEvent(CTabFolder.j ava:447)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2029)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Re: repopulate palette [message #139328 is a reply to message #139186] Tue, 22 June 2004 10:47 Go to previous messageGo to next message
First of all, which version of GEF are you working with?
Why don't you use GEF's palette view (introduced in 3.0)? Is it because you
want to share the same palette across different editor instances? Or are
you using an older version of GEF that does not have that view? If that is
the case, you can look at the PaletteView, PalettePage, PaletteViewerPage
and PaletteViewerProvider classes introduced in 3.0 to get an idea of how to
create your own PaletteView.
It is generally recommended that you not re-set the PaletteRoot for a viewer
and the associated EditDomain. Some things, such as the
PaletteCustomizerDialog, could still be holding on to the older model. It's
better to just repopulate the old root by removing all its children, and
then adding the new ones to it.
As far as the NPE below is concerned, I suspect that it will disappear if
you invoke setDefaultEntry(null) on the old palette root before setting the
new palette root on the viewer.
"Wang QS" <qwang@actuate.com> wrote in message
news:cb8jv4$n4j$1@eclipse.org...
> view.
> java.lang.NullPointerException
> at
1)
> at
> at
a:885)
> at
> at
a:885)
> at
> at
:826)
> at
tPart.java:160)
> at
15)
> at
teView.java:56)
> at
> at
> at
> at
> at
e.java:162)
> at
> at
:819)
> at
> at
> at
> at
ok.java:132)
> at
> at
java:257)
> at
> at
> at
..java:25)
Re: repopulate palette [message #139591 is a reply to message #139328] Wed, 23 June 2004 04:00 Go to previous message
Thanks very much.
removing all children is a good idea.
As you guessed, i want to share the same palette across different editor
instance. I'd like to create different palette view when different editor
was opened. Same type editor will use on palette.
> > view.
> > at
> 1)
> > at
> > at
> a:885)
> > at
> > at
> a:885)
> > at
> > at
> :826)
> > at
> tPart.java:160)
> > at
> 15)
> > at
> teView.java:56)
> > at
> > at
> > at
> > at
> > at
> e.java:162)
> > at
> > at
> :819)
> > at
> > at
> > at
> > at
> ok.java:132)
> > at
> > at
> java:257)
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> ..java:25)
Previous Topic:Unifying Undo & Redo stacks in a Multipage editor
Next Topic:probleme avec les scrolls
Current Time: Tue Jul 22 12:09:40 EDT 2025
Powered by FUDForum. Page generated in 0.03631 seconds
