| Unifying Undo & Redo stacks in a Multipage editor [message #139174] |
Tue, 22 June 2004 02:05  |
Originally posted by: brianv.phreaker.net
Hi Guys,
I have 2 page mutipage editor - one text page and the other is a GEF page.
Changes in the text are reflected in my GEF editor and viceversa.
Undo and Redo work well as long as I don't switch pages; if I do - I have to
flush the undo stacks depending on the commands executed before switching.
What I want to do right now, is interleave the undo and redo stacks of both
the pages.
ie. Suppose I am in the source page, and I delete some text, then I switch
to the GEF page and move some part around. Now, while in the GEF page, if I
press undo - first the part move is undone. If I press undo again, then the
text deletion should be undone (and the GEF page is probably refreshed
inorder to synch with the new source). This should work the other way round
too - the source should editor also be able to undo GEF commands.
Two approaches that I have thought of so far -
1) Use a single command stack - Extend the EditDomin (for GEF) and
re-implement IUndoManager (Text editor) to use this stack. This does not
look too bad for GEF , but seems like a lot of rework required in
implementing IUndoManager and plugging it in.
2) Second approach is to place a hook somewhere that is aware of the
commands being pushed on the stacks. It will probably maintain it's own list
of where the commands originated from (the source editor or the GEF editor).
When you undo or redo, this will delegate the action to the appropriate
stack.
Both the above don't seem like fun things to do ... any better ideas or
suggestions on the above techniques ?
Brian.
| Re: Unifying Undo & Redo stacks in a Multipage editor [message #139381 is a reply to message #139174] |
Tue, 22 June 2004 11:26   |
A single command stack is definitely the starting point. The rest is
dependant on the capabilities of your model. IBM's Page Designer has both
GEF and source view, and does exactly what you describe. I think that all
commands operate on the source's document.
"Brian Fernandes" <brianv@phreaker.net> wrote in message
news:cb8ib5$kdh$1@eclipse.org...
> Hi Guys,
to
both
> the pages.
I
the
round
list
editor).
> stack.
> Brian.
| Re: Unifying Undo & Redo stacks in a Multipage editor [message #139547 is a reply to message #139381] |
Tue, 22 June 2004 17:35  |
Great - thanks for the heads up. Page Designer seems to be a part of
Websphere... is the source to that available ? Websphere is a commercial
product, so I guess not.
I'll investiage this approach and post queries here.
Brian.
FUDForum. Page generated in 0.03849 seconds
