| Problems when connecting two elements [message #12752] |
Wed, 17 June 2009 16:33  |
Hi all,
I have the same problem as RÃŽmulo Arpini.
I am still a begginner on Eclipse, ok. Then I downloaded Eclipse Version:
3.4.2. I wanted to use the BMPM modeler, so I went to software update,
typed BPMN and installed 'bpmn project feature'. So I created a project
and then a bpmn diagram. But when I try to use a flow connector between
two elements (process, gateways, and so on) the editor crashes and I get
several errors in the log. And then it stays like this:
http://img178.imageshack.us/img178/9817/bugb.jpg
Yeah, exactly like that. Every time I try the arrow stays on the top left.
I've tried everything. Downloaded again, installed every stp component,
but no success at all.
Anyone here know how to solve this? : (
Best Regards,
Ivanna
| Re: Problems when connecting two elements [message #12773 is a reply to message #12752] |
Thu, 18 June 2009 09:25   |
Originally posted by: atoulme.intalio.com
Ivanna,
you can install the latest modeler by adding this update site URL:
http://download.eclipse.org/stp/bpmn-modeler/1.0.2/updates
It fixes that issue in particular.
Other threads on this newsgroup deal with this issue and explain in
greater detail why you hit that issue.
Antoine
Ivanna wrote:
> Hi all,
> Version: 3.4.2. I wanted to use the BMPM modeler, so I went to software
> update, typed BPMN and installed 'bpmn project feature'. So I created a
> project and then a bpmn diagram. But when I try to use a flow connector
> between two elements (process, gateways, and so on) the editor crashes
> and I get several errors in the log. And then it stays like this:
> left. I've tried everything. Downloaded again, installed every stp
> component, but no success at all.
> Best Regards,
> Ivanna
| Re: Problems when connecting two elements [message #499290 is a reply to message #481542] |
Fri, 20 November 2009 11:55  |
Verena, that's an official build.
And there is no 2.0 build in the pipe as of now.
Verena wrote:
> Hi Antoine,
> I also need a working copy of the bpmn-modeler. But I need an official
> release build. Can we expect a new version soon? When? And what about
> the 2.0 release? When will this on be official? The stable build of the
> 2.0 is also not reachable at the moment.
> --Verena
FUDForum. Page generated in 0.04301 seconds
