Home » Newcomers » Newcomers » Server Perspective/View
Server Perspective/View [message #138732] Sat, 18 February 2006 21:27 Go to next message
I just installed Eclipse 3.1.2. I am trying to use tomcat 5 as my server.
I can’t seem to figure out how to get to the Server Perspective or see
the Server View. I also don’t see Server options in the Preferences
screen.
Is there a plug-in or something I need to, what am I missing?
Chad
Re: Server Perspective/View [message #138770 is a reply to message #138732] Sat, 18 February 2006 23:58 Go to previous messageGo to next message
Originally posted by: gaoyuxiang.gmail.com
> server. I can?t seem to figure out how to get to the Server Perspective
> or see the Server View. I also don?t see Server options in the
> Preferences screen.
> Chad
Have you installed WTP on top of your Eclipse SDK? WTP contains plugins
necessary to operate Tomcat Server inside Eclipse.
Use this update site to get WTP:
http://download.eclipse.org/webtools/updates/
Sean GAO
Re: Server Perspective/View [message #138820 is a reply to message #138732] Sun, 19 February 2006 10:05 Go to previous messageGo to next message
> Preferences screen.
> Chad
Did you install the plugin from WTP. If not then you will need to do
this also or install a Tomcat plugin say, "Sysdeo Eclipse Tomcat
Launcher", http://www.sysdeo.com/eclipse/tomcatplugin
"Version 2.2.1 for Eclipse 2.1.*, Version 3.1 beta for Eclipse 3.0/3.1
Features: - Starting, stopping and restarting Tomcat 5.x, Tomcat 4.x or
3.3 - Registering Tomcat process to Eclipse debugger - Creating or
importing a WAR project (wizard can update server.xml file) - Adding
Java Projects to Tomcat classpath - Setting Tomcat JVM parameters,
classpath and bootclasspath - Exporting a Tomcat project to a WAR File -
Choosing Tomcat configuration file - Capability to use a special Tomcat
classloader to have classes in several java projects loaded at the same
classloader level than classes in a Tomcat project"
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Server Perspective/View [message #139074 is a reply to message #138770] Sun, 19 February 2006 16:23 Go to previous message
That worked great.
Chad
Previous Topic:UML plugin
Next Topic:save and osmindependent?
Current Time: Tue Jul 22 12:57:02 EDT 2025
Powered by FUDForum. Page generated in 0.11266 seconds
