Home » Eclipse Projects » Plugin Development Environment (PDE) » launching eclipse application
launching eclipse application [message #12734] Thu, 17 July 2008 10:28
Originally posted by: samie.ghauri.plexus.com
I am new to both linux and eclipse. I have installed eclipse 3.3 on my
linux x86 machine. I assume installing on linux meant just extracting from
the archive and copying into some desired location. I did so at the
following path:
/usr/IDES/eclipse 3.3/
I can launch eclipse with no problem, however when I tried to create a
plug in to add my tool chain, I ran it by run > debug as > eclipse
application, it gives an error:
usr/lib/Eclipse: not found
I am not quite sure what is missing. Any pointers please?
Samie
PS I am following the cookbook approach described in section of the
document: CDT plug-in developer guide found at:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. cdt.doc.isv/guide/mbs/extensibilityGuide/Managed_Build_Exten sibility.html
Previous Topic:Extension point schema for org.eclipse.ui.editors (and others) cannot be found
Next Topic:launching eclipse application
Current Time: Tue Jul 15 05:35:14 EDT 2025
Powered by FUDForum. Page generated in 0.10952 seconds
