| Problem with "Automatically refresh registers" option [message #138426] |
Fri, 11 February 2005 07:20  |
The default settings in "Windows>preferences>C/C++>GDB MI", are:
debugger timeout=10000
launch timeout = 30000
Automatically refresh register=true
Automatically refresh shared libraries=true.
My problem is the following:
When I create a new Managed C Project, then add source files then Build my
project, in "Windows>preferences>C/C++>GDB MI", the General settings for
GDB MI are not consistent:
debugger timeout=0
launch timeout = 0
Automatically refresh register=false
Automatically refresh shared libraries=false
Does someone have any idea of this problem ? Is it a known bug ?
After exiting Eclipse then launch Eclipse again, the GDB MI settings are
OK:
Thanks for advance
Jerome
| Re: Problem with "Automatically refresh registers" option [message #138876 is a reply to message #138804] |
Tue, 15 February 2005 04:12  |
I've copied these lines in the plugin.xml of my toolchain plugin (ST100
core).
Mikhail Khodjaiants wrote:
> What do you mean by "my plugin.xml"? These lines are in the plugin.xml file
> of the "org.eclipse.cdt.debug.mi.core" plugin.
> "jerome correnoz" <jerome.correnoz@st.com> wrote in message
> news:cuq6k0$nkj$1@www.eclipse.org...
>> My problem was solved by adding the following lines in my plugin.xml
>> <extension
>> point="org.eclipse.core.runtime.preferences">
>> <initializer
>> class="org.eclipse.cdt.debug.mi.core.MIPreferenceInitializer "/>
>> </extension>
>> Otherwise, it happen everytime I create a new Managed Project from ST
> type.
>> > I followed the steps you mentioned but I couldn't reproduce the problem.
>> > Does it happen everytime when you create a new managed project?
>> > news:cui7vb$uu2$1@www.eclipse.org...
>> >> Hello,
> debugger
>> >> timeout=10000
> my
> for
>> >> GDB MI are not consistent: debugger timeout=0
>> >> launch timeout = 0
> are
>> >> OK:
>> >> Thanks for advance
>> >> Jerome
FUDForum. Page generated in 0.04302 seconds
