Home » Newcomers » Newcomers » Tomcat Plugin
Tomcat Plugin [message #138293] Fri, 17 February 2006 09:04 Go to next message
Originally posted by: MarcW.dsaict.nl
I've got a old PC from an ex colleage and Eclipse appears to be installed
on it. Yes, lucky me. But if I try to do something with Tomcat from the
Eclipse environment I get an error. This is I think probably an installed
plugin. If I now start Tomcat, stop Tomcat or create a Tomcat project it
says:
Tomcat settings should be set in Tomcat Preference Page.
Ok, where is that? Since I don't know much about either products, is this
some Page in Tomcat or is it some Page in Eclipse. And which Tomcat
settings are they talking about. ?
Re: Tomcat Plugin [message #138297 is a reply to message #138293] Fri, 17 February 2006 09:23 Go to previous messageGo to next message
Originally posted by: a.b.com
Usually when it is installed by itself there is a Configure Tomcat option in
its Start menu...
Re: Tomcat Plugin [message #138313 is a reply to message #138297] Fri, 17 February 2006 09:37 Go to previous messageGo to next message
Chris:
"Usually when it is installed by itself there is a Configure Tomcat option
in
its Start menu..."
Yes, I think probably he had Tomcat on a drive mapping I do not have
anymore, so ... I should just reinstall that plugin if I want to use it.?
Re: Tomcat Plugin [message #139160 is a reply to message #138313] Mon, 20 February 2006 09:34 Go to previous message
Configuring Tomcat itself should not REQUIRE anything Eclipse-related. Try
this: Open a command line, cd to the bin directory of your tomcat install,
and run tomcat5w.exe. If it works, create a shortcut to it in the normal
way.
Previous Topic:save and osmindependent?
Next Topic:different ways to install plugins
Current Time: Fri Nov 07 02:14:08 EST 2025
Powered by FUDForum. Page generated in 0.12825 seconds
