Home » Archived » BIRT » how to make css common to multiple reports and editable?
how to make css common to multiple reports and editable? [message #138236] Thu, 02 March 2006 12:31 Go to next message
If you import a css file, it only allows you to import styles form that file
which it seems to embed in the report locally.
How to you have CSS for all your reports such that if you edit the style it
changes all the reports?
birt.
Re: how to make css common to multiple reports and editable? [message #138602 is a reply to message #138236] Thu, 02 March 2006 18:19 Go to previous messageGo to next message
One way of doing this would be
- Create a library
- Import the css file into a library
- share the library across mutliple report designs.
--Rima Kanguri
Re: how to make css common to multiple reports and editable? [message #138614 is a reply to message #138236] Thu, 02 March 2006 18:19 Go to previous message
OK, found the answer by trial and error: neither templates and importing
from style sheets helps, you have to create a library, add styles to a
theme, link the library, then use the theme.
Ive made some notes of the process:
http://www.simonhobbs.co.uk/wiki2/pmwiki.php/Main/Birt
I wish this had been in the field guide....
Simon.
"birt" <birt@ohds.co.uk> wrote in message
news:du7a4s$dd7$1@utils.eclipse.org...
> file which it seems to embed in the report locally.
> it changes all the reports?
> birt.
Previous Topic:multi-columns on a page
Next Topic:themes in libraries
Current Time: Thu Oct 30 01:30:20 EDT 2025
Powered by FUDForum. Page generated in 0.05688 seconds
