Home » Newcomers » Newcomers » Eclipse IDE Build Path and Merging
Eclipse IDE Build Path and Merging [message #138076] Fri, 17 February 2006 07:18 Go to next message
Originally posted by: manish.shah.tietoenator.com
I've just started to use Eclipse IDE. So far so good, however I have a
couple pof issues.
Firstly, I'm working on a large project. It takes several minutes to build
from clean, so I want to avoid doing this as much as possible. Whenever
someone from the team adds a new jar to the project classpath, Eclipse
seems to rebuild everything. Is there any way to disable this?
Secondly, I seem to have to do a lot of manual merging. Does anyone
recommend a merge plugin for Eclipse that can deal with conflicts a bit
better than the default one. Or at least one that allows you to move code
accross between revisions without having to manually cut 'n' paste.
Thanks in advance,
Manish
Re: Eclipse IDE Build Path and Merging [message #140647 is a reply to message #138076] Mon, 27 February 2006 18:29 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
Manish Shah wrote:
> couple pof issues.
> build from clean, so I want to avoid doing this as much as possible.
> Whenever someone from the team adds a new jar to the project classpath,
> Eclipse seems to rebuild everything. Is there any way to disable this?
No. Think about it, if the classpath is changed (by adding or changing a
JAR, for example) Eclipse must rebuild that entire project because it
has no way of knowing what changes in the compilation a JAR change will
trigger, until it has actually done the recompile.
> code accross between revisions without having to manually cut 'n' paste.
Are you using CVS? The Eclipse CVS merge capability is by far the best
I've ever seen. Please explain your usage scenario in which you feel it
is not very good.
Hope this helps,
Eric
Previous Topic:Debugging
Next Topic:Remove application
Current Time: Tue Nov 18 12:54:44 EST 2025
Powered by FUDForum. Page generated in 0.09488 seconds
