| pdf button not showed in viewer [message #138063] |
Thu, 02 March 2006 09:07  |
Originally posted by: jlopez.asmws.com
I'm using birt 2.01 with reports created with 1.0.1, and with new reports,
and I can't see the pdf button generator in the viewer. there's any kind
of parameter that shows the button? I tried with &__format=pdf but
nothing happened, I only have the option for export to CSV , change
parameters.
the itext-1.3.jar is present in the plugin/emiter directory .
thanks.
| Re: pdf button not showed in viewer [message #138226 is a reply to message #138063] |
Thu, 02 March 2006 11:49  |
> parameters.
Check out the thread "Problem with print".
Please let me know if the suggested patch works for you.
FUDForum. Page generated in 0.03051 seconds
