Home » Modeling » GMF (Graphical Modeling Framework) » Custom Figure State Chart
Custom Figure State Chart [message #137947] Wed, 20 June 2007 10:20 Go to next message
i want to make a Figure for the startstate and the finalstate in a
statechart. Is there a good documentation to realize something like
that? I have seen the BPMN tutorial, but i want the figures completely
define in gmfgraph without external files oder code changing.
I've tried it with Ellipse and a Polygon figure child. And then i've
defined the circle over template points. But this looks not very good
cause the border, when i select the figure, looks like a rectangle.
Greetings
Re: Custom Figure State Chart [message #138877 is a reply to message #137947] Fri, 22 June 2007 11:47 Go to previous message
Guess, there are no issues with start state (merely a filled ellipse),
right? For the end state, if you are ok with non-resizable element, see
attached model. If you need end state to be resizable, check StateMachine
diagram from MDT project.
Artem
"J
  • Attachment: My.gmfgraph
    (Size: 1.06KB, Downloaded 187 times)
Previous Topic:Name Label is not visible
Next Topic:Retrieving connection information
Current Time: Sun Jul 27 06:31:44 EDT 2025
Powered by FUDForum. Page generated in 0.03228 seconds
